Kubota L2850DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book engine 01t001 Crankcase 100k032701t002 Oil Pan 100k032701t003 Piston And Crankshaft 100k032701t004 Main Bearing Case 100k032701t00501 Flywheel(Dc) 100k032701t00502 Flywheel(Sc) 100k032701t006 Cylinder Head 100k032701t007 Valve And Rocker Arm 100k032701t008 Nozzle And Glow Plug 100k032701t009 Cylinder Head Cover 100k032701t010 Inlet Manifold 100k032701t015 Camshaft 100k032701t016 Gear Case 100k032701t017 Water Pump 100k032701t018 Water Flange 100k032701t019 Fuel Camshaft 100k032701t020 Injection Pump 100k032701t021 Injection Pump [component Parts] 100k032701t022 Engine Stop Lever 100k032701t023 Speed Control Plate 1 100k032701t024 Speed Control Plate 2 100k032701t025 Governor 100k032701t01101 Air Cleaner 100k032701t01102 Double Air Cleaner [option] 100k032701t012 Pre-cleaner [option] 100k032701t013 Exhaust Manifold 100k032701t01401 Muffler 100k032701t01402 Under Muffler [option] 100k032701t026 Stop Rod 100k032701t027 Accelerator Lever 100k032701t028 Accellerator Linkage 100k0327fuel System 01t029 Fuel Tank 100k032701t030 Fuel Filter 100k032701t031 Fuel Filter [component Parts] 100k0327cooling Water System 01t032 Fan 100k032701t033 Water Pipe 100k032701t034 Radiator 100k032701t035 Shutter 100k0327electrical System 01t036 Dynamo 100k032701t037 Dynamo [component Parts] 100k032701t038 Starter 100k032701t039 Starter [component Parts] 100k032701t040 Battery 100k032701t04101 Switch And Regulator Except [fr] 100k032701t04201 Panel [with Easy Checker] 100k032701t04202 Panel [without Easy Checker]except [fr]100k032701t04301 Light Except [fr] 100k032701t04501 Electrical Wiring [with Easychecker] Except [fr]100k032701t04502 Electrical Wiring [without Easychecker] Except [fr]100k0327clutch 01t04601 Clutch (Dc) 100k032701t04602 Clutch (Sc) 100k032701t04701 Clutch Lever (Dc) 100k032701t04702 Clutch Lever (Sc) 100k032701t048 Clutch Pedal 100k0327
