Kubota L3250DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k032901t002 Oil Pan 100k032901t003 Piston And Crankshaft 100k032901t004 Main Bearing Case 100k032901t00501 Flywheel(Dc) 100k032901t006 Cylinder Head 100k032901t007 Valve And Rocker Arm 100k032901t008 Nozzle And Glow Plug 100k032901t009 Cylinder Head Cover 100k032901t010 Inlet Manifold 100k032901t015 Camshaft 100k032901t016 Gear Case 100k032901t017 Water Pump 100k032901t018 Water Flange 100k032901t019 Fuel Camshaft 100k032901t020 Injection Pump 100k032901t021 Injection Pump [component Parts] 100k032901t022 Engine Stop Lever 100k032901t023 Speed Control Plate 1 100k032901t025 Governor 100k032901t01101 Air Cleaner 100k032901t01102 Double Air Cleaner [option] 100k032901t012 Pre-cleaner [option] 100k032901t013 Exhaust Manifold 100k032901t01401 Muffler 100k032901t01402 Under Muffler [option] 100k032901t026 Stop Rod 100k032901t027 Accelerator Lever 100k032901t028 Accellerator Linkage 100k0329fuel System 01t029 Fuel Tank 100k032901t030 Fuel Filter 100k032901t031 Fuel Filter [component Parts] 100k0329cooling Water System 01t032 Fan 100k032901t033 Water Pipe 100k032901t034 Radiator 100k032901t035 Shutter 100k0329electrical System 01t036 Dynamo 100k032901t037 Dynamo [component Parts] 100k032901t038 Starter 100k032901t039 Starter [component Parts] 100k032901t040 Battery 100k032901t04101 Switch And Regulator Except [fr] 100k032901t04201 Panel [with Easy Checker] 100k032901t04301 Light Except [fr] 100k032901t04501 Electrical Wiring [with Easy Checker]except [fr]100k0329clutch 01t04601 Clutch (Dc) 100k032901t04701 Clutch Lever (Dc) 100k032901t048 Clutch Pedal 100k032901t049 Clutch Housing 100k0329transmission 01t050 Transmission Case 100k032901t05101 Main Shaft (Dc) 100k032901t05202 Counter Shaft [synchro Mesh] 100k032901t053 Counter Shaft 2 100k032901t054 Pto Counter Shaft 1 (Dc) 100k032901t055 Pto Counter Shaft 2 (Dc) 100k032901t057 Pto Shaft 100k032901t059 Reverse Shaft 100k0329speed Change Lever 01t060 Main And Shuttle Gear Shift Lever 100k032901t061 Main Gear Shift Linkage System 100k0329​
