Kubota L2250DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Bookengine 01t001 Crankcase 100k033701t002 Oil Pan 100k033701t003 Piston And Crankshaft 100k033701t004 Main Bearing Case 100k033701t00501 Flywheel(Dc) 100k033701t00502 Flywheel(Sc) 100k033701t006 Cylinder Head 100k033701t007 Valve And Rocker Arm 100k033701t008 Nozzle And Glow Plug 100k033701t009 Cylinder Head Cover 100k033701t010 Inlet Manifold 100k033701t015 Camshaft 100k033701t016 Gear Case 100k033701t017 Water Pump 100k033701t018 Water Flange 100k033701t019 Fuel Camshaft 100k033701t020 Injection Pump 100k033701t021 Injection Pump [component Parts] 100k033701t022 Engine Stop Lever 100k033701t023 Speed Control Plate 1 100k033701t024 Speed Control Plate 2 100k033701t025 Governor 100k033701t01101 Air Cleaner 100k033701t01102 Double Air Cleaner [option] 100k033701t012 Pre-cleaner [option] 100k033701t013 Exhaust Manifold 100k033701t01401 Muffler 100k033701t01402 Under Muffler [option] 100k033701t02601 Stop Rod Except [gr] 100k033701t027 Accelerator Lever 100k033701t028 Accelerator Linkage 100k0337fuel System 01t029 Fuel Tank 100k033701t030 Fuel Filter 100k033701t031 Fuel Filter [component Parts] 100k0337cooling Water System 01t032 Fan 100k033701t033 Water Pipe 100k033701t034 Radiator 100k033701t035 Shutter 100k0337electrical System 01t03601 Dynamo Except [ca] 100k033701t03701 Dynamo [component Parts] 100k033701t038 Starter 100k033701t03901 Starter [component Parts] 100k033701t03902 Starter [component Parts] 100k033701t040 Battery 100k033701t04101 Switch And Regulator Except[fr][gr][po]100k033701t04201 Panel [with Easy Checker] Except[fr][gr][po][au]100k033701t04202 Panel [without Easy Checker][a][fr][gr][po][au]100k033701t04301 Light Except [fr] 100k033701t04601 Electrical Wiring [with Easychecker] [a]100k033701t04602 Electrical Wiring [without Easychecker] [a][au]100k0337clutch 01t04701 Clutch(Dc) 100k0337​
