Kubota L2850F Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k032801t002 Oil Pan 100k032801t003 Piston And Crankshaft 100k032801t004 Main Bearing Case 100k032801t00501 Flywheel(Dc) 100k032801t00502 Flywheel(Sc) 100k032801t006 Cylinder Head 100k032801t007 Valve And Rocker Arm 100k032801t008 Nozzle And Glow Plug 100k032801t009 Cylinder Head Cover 100k032801t010 Inlet Manifold 100k032801t015 Camshaft 100k032801t016 Gear Case 100k032801t017 Water Pump 100k032801t018 Water Flange 100k032801t019 Fuel Camshaft 100k032801t020 Injection Pump 100k032801t021 Injection Pump [component Parts] 100k032801t022 Engine Stop Lever 100k032801t023 Speed Control Plate 1 100k032801t024 Speed Control Plate 2 100k032801t025 Governor 100k032801t01101 Air Cleaner 100k032801t01102 Double Air Cleaner [option] 100k032801t012 Pre-cleaner [option] 100k032801t013 Exhaust Manifold 100k032801t01401 Muffler 100k032801t01402 Under Muffler [option] 100k032801t026 Stop Rod 100k032801t027 Accelerator Lever 100k032801t028 Accellerator Linkage 100k0328fuel System 01t029 Fuel Tank 100k032801t030 Fuel Filter 100k032801t031 Fuel Filter [component Parts] 100k0328cooling Water System 01t032 Fan 100k032801t033 Water Pipe 100k032801t034 Radiator 100k032801t035 Shutter 100k0328electrical System 01t036 Dynamo 100k032801t037 Dynamo [component Parts] 100k032801t038 Starter 100k032801t039 Starter [component Parts] 100k032801t040 Battery 100k032801t04101 Switch And Regulator Except [fr] 100k032801t04201 Panel [with Easy Checker] 100k032801t04202 Panel [without Easy Checker]except [fr]100k032801t04301 Light Except [fr] 100k032801t04501 Electrical Wiring [with Easychecker] Except [fr]100k032801t04502 Electrical Wiring [without Easychecker] Except [fr]100k0328clutch 01t04601 Clutch (Dc) 100k032801t04602 Clutch (Sc) 100k032801t04701 Clutch Lever (Dc) 100k032801t04702 Clutch Lever (Sc) 100k0328​
