Item Part No. Description Book Engine 01t001 Crankcase 100k033801t002 Oil Pan 100k033801t003 Piston And Crankshaft 100k033801t004 Main Bearing Case 100k033801t00501 Flywheel(Dc) 100k033801t00502 Flywheel(Sc) 100k033801t006 Cylinder Head 100k033801t007 Valve And Rocker Arm 100k033801t008 Nozzle And Glow Plug 100k033801t009 Cylinder Head Cover 100k033801t010 Inlet Manifold 100k033801t015 Camshaft 100k033801t016 Gear Case 100k033801t017 Water Pump 100k033801t018 Water Flange 100k033801t019 Fuel Camshaft 100k033801t020 Injection Pump 100k033801t021 Injection Pump [component Parts] 100k033801t022 Engine Stop Lever 100k033801t023 Speed Control Plate 1 100k033801t024 Speed Control Plate 2 100k033801t025 Governor 100k033801t01101 Air Cleaner 100k033801t01102 Double Air Cleaner [option] 100k033801t012 Pre-cleaner [option] 100k033801t013 Exhaust Manifold 100k033801t01401 Muffler 100k033801t01402 Under Muffler [option] 100k033801t02601 Stop Rod Except [gr] 100k033801t027 Accelerator Lever 100k033801t028 Accelerator Linkage 100k0338fuel System 01t029 Fuel Tank 100k033801t030 Fuel Filter 100k033801t031 Fuel Filter [component Parts] 100k0338cooling Water System 01t032 Fan 100k033801t033 Water Pipe 100k033801t034 Radiator 100k033801t035 Shutter 100k0338electrical System 01t03601 Dynamo Except [ca] 100k033801t03701 Dynamo [component Parts] 100k033801t038 Starter 100k033801t03901 Starter [component Parts] 100k033801t03902 Starter [component Parts] 100k033801t040 Battery 100k033801t04101 Switch And Regulator Except [fr][gr][po] 100k033801t04201 Panel [with Easy Checker] Except[fr][gr][po][au]100k033801t04202 Panel [without Easy Checker][a][fr][gr][po][au]100k033801t04301 Light Except [fr] 100k033801t04601 Electrical Wiring [with Easy Checker] [a] 100k033801t04602 Electrical Wiring [without Easy Checker][a][au]100k0338clutch 01t04701 Clutch(Dc) 100k033801t04702 Clutch(Sc) 100k033801t04801 Clutch Lever(Dc) 100k033801t04802 Clutch Lever(Sc) 100k033801t049 Clutch Pedal 100k033801t050 Clutch Housing 100k0338transmission 01t051 Transmission Case 100k0338
