Item Part No. Description Book Engine 01t001 Crankcase 100k033901t002 Oil Pan 100k033901t003 Piston And Crankshaft 100k033901t004 Main Bearing Case 100k033901t00501 Flywheel(Dc) 100k033901t00502 Flywheel(Sc) 100k033901t006 Cylinder Head 100k033901t007 Valve And Rocker Arm 100k033901t008 Nozzle And Glow Plug 100k033901t009 Cylinder Head Cover 100k033901t010 Inlet Manifold 100k033901t015 Camshaft 100k033901t016 Gear Case 100k033901t017 Water Pump 100k033901t018 Water Flange 100k033901t019 Fuel Camshaft 100k033901t020 Injection Pump 100k033901t021 Injection Pump [component Parts] 100k033901t022 Engine Stop Lever 100k033901t023 Speed Control Plate 1 100k033901t024 Speed Control Plate 2 100k033901t025 Governor 100k033901t01101 Air Cleaner 100k033901t01102 Double Air Cleaner [option] 100k033901t012 Pre-cleaner [option] 100k033901t013 Exhaust Manifold 100k033901t01401 Muffler 100k033901t01402 Under Muffler [option] 100k033901t02601 Stop Rod Except [gr] 100k033901t027 Accelerator Lever 100k033901t028 Accelerator Linkage 100k0339fuel System 01t029 Fuel Tank 100k033901t030 Fuel Filter 100k033901t031 Fuel Filter [component Parts] 100k0339cooling Water System 01t032 Fan 100k033901t033 Water Pipe 100k033901t034 Radiator 100k033901t035 Shutter 100k0339electrical System 01t03601 Dynamo Except [ca] 100k033901t03701 Dynamo [component Parts] 100k033901t038 Starter 100k033901t03901 Starter [component Parts] 100k033901t03902 Starter [component Parts] 100k033901t040 Battery 100k033901t04101 Switch And Regulator Except[fr][gr][po]100k033901t04201 Panel [with Easy Checker] Except[fr][gr][po][au]100k033901t04202 Panel [without Easy Checker][a][fr][gr][po][au]100k033901t04301 Light Except [fr] 100k033901t04601 Electrical Wiring [with Easychecker] [a]100k033901t04602 Electrical Wiring [without Easychecker] [a][au]100k0339clutch 01t04701 Clutch(Dc) 100k033901t04702 Clutch(Sc) 100k0339
