Item Part No. Description Book Engine 010001 Crankcase 100a0267010002 Oil Pan 100a0267010003 Cylinder Head 100a0267010004 Gear Case 100a0267010005 Head Cover 100a0267010006 Oil Filter 100a0267010007 Dipstick And Guide 100a0267010008 Oil Pump 100a0267010100 Main Bearing Case 100a0267010101 Camshaft And Idle Gear Shaft 100a0267010102 Piston And Crankshaft 100a0267010103 Flywheel 100a0267010105 Fuel Camshaft And Governor Shaft 100a0267010200 Idle Apparatus 100a0267010201 Stop Solenoid 100a0267010202 Injection Pump 100a0267010204 Governor 100a0267010205 Speed Control Plate 100a0267010206 Nozzle Holder And Glow Plug 100a0267010207 Nozzle Holder [component Parts] 100a0267010305 Fuel Pump Cover 100a0267010400 Dynamo And Pulley 100a0267010401 Dynamo (Component Parts) 100a0267010404 Starter 100a0267010405 Starter [component Parts] 100a0267010406 Oil Switch And Plug 100a0267010500 Water Flange And Thermostat 100a0267010501 Water Pump 100a0267010503 Water Pipe 100a0267010504 Fan 100a0267010600 Valve And Rocker Arm 100a0267010601 Inlet Manifold 100a0267010602 Exhaust Manifold 100a0267020603 Air Cleaner 100a0267020605 Muffler 100a0267010903 Piston Kit [option] 100a0267010906 Upper Gasket Kit [option] 100a0267010907 Lower Gasket Kit [option] 100a0267fuel System 02a010 Accelerator Lever 100a026702a100 Fuel Tank 100a0267cooling Water System 02a210 Water Pipe 100a026702a220 Radiator 100a0267electrical System 02b010 Battery 100a026702b100 Electrical Parts 100a0267transmission 02c400 Hst 100a026702c40501 Hst [component Parts] 100a026702c40502 Hst [component Parts] 100a026702c420 Universal Joint/hst Fan 100a0267rear Tire 02d200 Rear Wheel 100a0267brake 02d510 Brake 100a026702d525 Parking Brake Lever 100a026702d530 Brake Rod 100a0267speed Change 02d700 Speed Change Pedal 100a026702d730 Pto Clutch Control Lever/wire 100a0267front Axle 02e010 Front Axle 100a0267front Tire 02e100 Front Wheel 100a0267chassis 02e500 Main Frame/steering Support 100a0267engine 02e550 Engine Support 100a0267steering 02e700 Power Steering/steering Handle 100a0267
