Kubota ZD21 Zero Turn Without the Roll Bar Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 010001 Crank Case 100k066201000202 Oil Pan 100k0662010003 Cylinder Head 100k066201000402 Gear Case 100k0662010005 Head Cover 100k0662010006 Oil Filter 100k0662010007 Dipstick And Guide 100k0662010008 Oil Pump 100k066201010002 Main Bearing Case 100k0662010101 Camshaft And Idle Gear Shaft 100k066201010202 Piston And Crankshaft 100k0662010103 Flywheel 100k0662010105 Fuel Camshaft And Governorshaft100k0662010200 Idle Apparatus 100k0662010201 Stop Solenoid 100k0662010202 Injection Pump 100k0662010203 Injection Pump [component Parts] 100k0662010204 Governor 100k0662010205 Speed Control Platec 100k0662010206 Nozzle Holder And Glow Plug 100k0662010207 Nozzle Holder [component Parts] 100k0662010305 Cover 100k0662010400 Dynamo And Pulley 100k0662010401 Dynamo [component Parts] 100k0662010404 Starter 100k0662010405 Starter [component Parts] 100k0662010406 Oil Switch/thermometer And Plug 100k066201050002 Water Flange And Thermostat 100k0662010501 Water Pump 100k066201050302 Water Pipe 100k0662010504 Fan 100k0662010600 Valve And Rocker Arm 100k0662010601 Inlet Manifold 100k0662010602 Exhaust Manifold 100k0662010901 Upper Gasket Kit [option] 100k0662010902 Lower Gasket Kit [option] 100k0662010906 Piston Kit [option] 100k0662020603 Air Cleaner 100k0662020605 Muffler 100k066202a010 Accelerator Lever 100k0662fuel System 02a101 Fuel Tank 100k066202a110 Fuel Pipe 100k0662cooling Water System 02a410 Water Pipe 100k066202a420 Radiator 100k066202a425 Dustproof Plate 100k066202a430 Reserve Tank 100k0662electrical System 02a535 Battery 100k066202b105 Switch/sensor 100k066202b107 Switch/controller 100k066202b230 Electrical Wiring 100k0662clutch/transmission/rear Axle 02c101 Clutch 100k066202c420 Transmission Case 100k066202c422 Charge Pump Case 100k066202c426 Rear Axle Case Rh 100k066202c427 Rear Axle Case Lh 100k066202c440 Hst 100k0662​
