Item Part No. Description Bookengine 010001 Crank Case 100k071001000201 Oil Pan 100k0710010003 Cylinder Head 100k071001000401 Gear Case 100k0710010005 Head Cover 100k0710010006 Oil Filter 100k0710010007 Dipstick And Guide 100k0710010008 Oil Pump 100k071001010001 Main Bearing Case 100k0710010101 Camshaft And Idle Gear Shaft 100k071001010201 Piston And Crankshaft 100k0710010103 Flywheel 100k0710010105 Fuel Camshaft And Governor Shaft 100k0710010200 Idle Apparatus 100k0710010201 Stop Solenoid 100k0710010202 Injection Pump 100k0710010204 Governor 100k071001020501 Speed Control Platec 100k071001020502 Speed Control Platec 100k0710010206 Nozzle Holder And Glow Plug 100k0710010207 Nozzle Holder [component Parts] 100k0710010305 Cover 100k0710010406 Oil Switch/thermometer And Plug 100k071001050001 Water Flange And Thermostat 100k0710010501 Water Pump 100k071001050301 Water Pipe 100k0710010600 Valve And Rocker Arm 100k0710010601 Inlet Manifold 100k0710010602 Exhaust Manifold 100k0710010901 Upper Gasket Kit [option] 100k0710010902 Lower Gasket Kit [option] 100k0710010906 Piston Kit [option] 100k0710cooling Water System 01a401 Fan 100k0710electrical System 01a521 Dynamo 100k071001a523 Dynamo [component Parts] 100k071001a525 Starter 100k071001a530 Starter [component Parts] 100k0710hood(Bonnet) 03m301 Rops 100k0710option 04s86001 Weight Kit [option] 100k071004s86002 Weight Kit [option] 100k0710engine 020603 Air Cleaner 100k0710020605 Muffler 100k071002a010 Accelerator Lever 100k0710fuel System 02a101 Fuel Tank 100k071002a110 Fuel Pipe 100k0710cooling Water System 02a410 Water Pipe 100k071002a420 Radiator 100k071002a425 Dustproof Plate 100k071002a430 Reserve Tank 100k0710electrical System 02a535 Battery 100k071002b105 Switch/sensor 100k071002b107 Switch/controller 100k071002b230 Electrical Wiring 100k0710clutch/transmission/rear Axle 02c101 Clutch 100k071002c420 Transmission Case 100k071002c422 Charge Pump Case 100k071002c426 Rear Axle Case Rh 100k071002c427 Rear Axle Case Lh 100k071002c440 Hst 100k0710
