Kubota BX23D Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 011001 Crankcase 100z0254011002 Oil Pan 100z0254011003 Cylinder Head 100z0254011004 Gear Case 100z0254011005 Head Cover 100z0254011006 Oil Filter 100z0254011007 Dipstick And Guide 100z0254011100 Main Bearing Case 100z0254011101 Camshaft And Idle Gear Shaft 100z0254011102 Piston And Crankshaft 100z0254011103 Flywheel 100z0254011105 Fuel Camshaft And Governor Shaft 100z0254011200 Idle Apparatus 100z0254011201 Stop Solenoid 100z0254011202 Injection Pump 100z0254011204 Governor 100z0254011205 Speed Control Plate 100z0254011206 Nozzle Holder And Glow Plug 100z0254011207 Nozzle Holder [component Parts] 100z0254011305 Cover 100z0254011400 Dynamo And Pulley 100z0254011401 Dynamo [component Parts] 100z0254011404 Starter 100z0254011405 Starter [component Parts] 100z0254011406 Oil Switch/thermometer And Plug 100z0254011500 Water Flange And Thermostat 100z0254011501 Water Pump 100z0254011504 Fan 100z0254011600 Valve And Rocker Arm 100z0254011601 Inlet Manifold 100z0254011602 Exhaust Manifold 100z0254011700 Hydraulic Pump 100z0254011701 Hydraulic Pump [component Parts] 100z0254011900 Upper Gasket Kit 100z0254011901 Lower Gasket Kit 100z0254011603 Air Cleaner 100z0254011605 Muffler 100z0254011703 Hydraulic Pump Cover 100z025401a001 Accelerator Lever 100z0254fuel System 01a101 Fuel Tank 100z025401a110 Fuel Pipe 100z0254cooling Water System 01a410 Water Pipe 100z025401a420 Radiator 100z0254electrical System 01a535 Battery 100z025401b115 Panel Board 100z025401b215 Switch/sensor 100z025401b30102 Head Right 100z025401b303 Hazard Light/tail Light 100z025401b310 Winker Lamp 100z025401b50102 Electrical Wiring 100z0254frame 01c413 Front Frame 100z025401c417 Sub Frame 100z025401c419 Engine Support 100z0254transmission/hst/rear Axle 01c420 Transmission Case 100z025401c427 Rear Axle Case 100z025401d001 Clutch Shaft/output Shaft 100z025401d005 Propeller Shaft 100z0254​
