Item Part No. Description Bookengine 021001 Crankcase 100k0552021002 Oil Pan 100k0552021003 Cylinder Head 100k0552021004 Gear Case 100k0552021005 Head Cover 100k0552021006 Oil Filter 100k0552021007 Dipstick And Guide 100k0552021100 Main Bearing Case 100k0552021101 Camshaft And Idle Gear Shaft 100k0552021102 Piston And Crankshaft 100k0552021103 Flywheel 100k0552021105 Fuel Camshaft And Governor Shaft 100k0552021200 Engine Stop Lever 100k0552021201 Stop Solenoid 100k0552021202 Injection Pump 100k0552021203 Injection Pump [component Parts] 100k0552021204 Governor [old Type] 100k055202120401 Governor [new Type] 100k0552021205 Speed Control Plate 100k0552021206 Nozzle Holder And Glow Plug 100k0552021207 Nozzle Holder [component Parts] 100k0552021301 Fuel Pump(Mechanical) 100k0552021400 Dynamo And Pulley 100k0552021401 Dynamo [component Parts] 100k0552021404 Starter 100k0552021405 Starter [component Parts] 100k0552021406 Oil Switch/thermometer And Plug 100k0552021500 Water Flange And Thermostat 100k0552021501 Water Pump 100k0552021504 Fan 100k0552021600 Valve And Rocker Arm 100k0552021601 Inlet Manifold 100k0552021602 Exhaust Manifold 100k0552021703 Hydraulic Pump Cover 100k0552021900 Upper Gasket Kit 100k0552021901 Lower Gasket Kit 100k0552011603 Air Cleaner 100k0552011605 Muffler 100k055201a00102 Accelerator Lever 100k0552fuel System 01a101 Fuel Tank 100k055201a11002 Fuel Pipe 100k0552cooling Water System 01a41002 Water Pipe 100k055201a42002 Radiator 100k0552electrical System 01a53502 Battery 100k055201b115 Panel Board 100k055201b215 Switch/sensor 100k055201b301 Head Right 100k055201b303 Hazard Light/tail Light 100k055201b501 Electrical Wiring 100k0552transmission/hst/rear Axle 01c420 Transmission Case 100k055201c427 Rear Axle Case 100k055201d001 Clutch Shaft/output Shaft 100k055201d005 Propeller Shaft 100k055201d010 Hst 100k055201d015 Hst [component Parts] 100k055201d107 Range Gear Shaft 100k055201d135 Pto Shaft 100k055201d137 Mid Pto 100k055201d140 Rear Differential 100k055201d141 Fwd Idle Shaft 100k0552
