Kubota ZD21F Zero Turn with Factory Installed Roll Bar Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 010001 Crank Case 100k071201000202 Oil Pan 100k0712010003 Cylinder Head 100k071201000402 Gear Case 100k0712010005 Head Cover 100k0712010006 Oil Filter 100k0712010007 Dipstick And Guide 100k0712010008 Oil Pump 100k071201010002 Main Bearing Case 100k0712010101 Camshaft And Idle Gear Shaft 100k071201010202 Piston And Crankshaft 100k0712010103 Flywheel 100k0712010105 Fuel Camshaft And Governor Shaft 100k0712010200 Idle Apparatus 100k0712010201 Stop Solenoid 100k0712010202 Injection Pump 100k0712010204 Governor 100k071201020501 Speed Control Platec 100k071201020502 Speed Control Platec 100k0712010206 Nozzle Holder And Glow Plug 100k0712010207 Nozzle Holder [component Parts] 100k0712010305 Cover 100k0712010406 Oil Switch/thermometer And Plug 100k071201050002 Water Flange And Thermostat 100k0712010501 Water Pump 100k071201050302 Water Pipe 100k0712010600 Valve And Rocker Arm 100k0712010601 Inlet Manifold 100k0712010602 Exhaust Manifold 100k0712020603 Air Cleaner 100k0712020605 Muffler 100k0712010901 Upper Gasket Kit [option] 100k0712010902 Lower Gasket Kit [option] 100k0712010906 Piston Kit [option] 100k071202a010 Accelerator Lever 100k0712fuel System 02a101 Fuel Tank 100k071202a110 Fuel Pipe 100k0712cooling Water System 01a401 Fan 100k071202a410 Water Pipe 100k071202a420 Radiator 100k071202a425 Dustproof Plate 100k071202a430 Reserve Tank 100k0712electrical System 01a521 Dynamo 100k071201a523 Dynamo [component Parts] 100k071201a525 Starter 100k071201a530 Starter [component Parts] 100k071202a535 Battery 100k071202b105 Switch/sensor 100k071202b107 Switch/controller 100k071202b230 Electrical Wiring 100k0712clutch/transmission/rear Axle 02c101 Clutch 100k071202c420 Transmission Case 100k071202c422 Charge Pump Case 100k071202c426 Rear Axle Case Rh 100k071202c427 Rear Axle Case Lh 100k071202c440 Hst 100k071202c45202 Hst Rh 1 [component Parts] 100k071202c45302 Hst Rh 2 [component Parts] 100k071202c45702 Hst Lh 1 [component Parts] 100k0712​
