Item Part No. Description Book Engine 010001 Crank Case 100a0169010002 Oil Pan 100a0169010003 Cylinder Head 100a0169010004 Gear Case 100a016901000501 Head Cover 100a016901000502 Head Cover 100a0169010006 Oil Filter 100a0169010007 Dipstick And Guide 100a0169010100 Main Bearing Case 100a0169010101 Camshaft And Idle Gear Shaft 100a0169010102 Piston And Crankshaft 100a0169010103 Flywheel 100a0169010105 Fuel Camshaft And Governor Shaft 100a0169010200 Idle Apparatus 100a0169010201 Stop Solenoid 100a0169010202 Injection Pump 100a0169010204 Governor 100a0169010205 Speed Control Platec 100a0169010206 Nozzle Holder And Glow Plug 100a0169010207 Nozzle Holder [component Parts] 100a0169010305 Cover 100a0169010400 Dynamo And Pulley 100a0169010401 Dynamo [component Parts] 100a0169010404 Starter 100a0169010405 Starter [component Parts] 100a0169010406 Oil Switch And Thermometer 100a0169010500 Water Flange And Thermostat 100a0169010501 Water Pump 100a0169010504 Fan 100a0169010600 Valve And Rocker Arm 100a016901060101 Inlet Manifold 100a016901060102 Inlet Manifold 100a0169010602 Exhaust Manifold 100a0169020603 Air Cleaner 100a0169020605 Muffler 100a0169010901 Upper Gasket Kit [option] 100a0169010902 Lower Gasket Kit [option] 100a0169fuel System 02a010 Accelerator Lever 100a016902a101 Fuel Tank 100a016902a110 Fuel Pipe 100a0169cooling Water System 02a410 Water Pipe 100a016902a420 Radiator 100a016902a425 Dustproof Plate 100a016902a430 Reserve Tank 100a0169erectrical System 02a535 Battery 100a016902b105 Switch/sensor 100a016902b107 Switch/controller 100a016902b230 Electrical Wiring 100a0169clutch/transmission/rear Axle 02c101 Clutch 100a016902c420 Transmission Case 100a016902c422 Charge Pump Case 100a016902c426 Rear Axle Case Rh 100a016902c427 Rear Axle Case Lh 100a016902c440 Hst 100a016902c452 Hst Rh 1 [component Parts] 100a016902c453 Hst Rh 2 [component Parts] 100a016902c457 Hst Lh 1 [component Parts] 100a016902c458 Hst Lh 2 [component Parts] 100a016902d001 Clutch Shaft 100a0169
