Kubota BX1830D Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 010001 Crankcase 100k0781010002 Oil Pan 100k0781010003 Cylinder Head 100k0781010004 Gear Case 100k0781010005 Head Cover 100k0781010006 Oil Filter 100k0781010007 Dipstick And Guide 100k0781010008 Oil Pump 100k0781010100 Main Bearing Case 100k0781010101 Camshaft And Idle Gearshaft100k0781010102 Piston And Crankshaft 100k0781010103 Flywheel 100k0781010105 Fuel Camshaft And Governor Shaft100k0781010200 Idle Apparatus 100k0781010201 Stop Solenoid 100k0781010202 Injection Pump 100k0781010204 Governor 100k0781010205 Speed Control Plate 100k0781010206 Nozzle Holder And Glow Plug100k0781010207 Nozzle Holder[component Parts]100k0781010305 Cover 100k0781010400 Dynamo And Pulley 100k0781010401 Dynamo [component Parts]100k0781010404 Starter 100k0781010405 Starter [component Parts]100k0781010406 Oil Switch/thermometer And Plug100k0781010500 Water Flange Andthermostat100k0781010501 Water Pump 100k0781010503 Water Pipe 100k0781010504 Fan 100k0781010600 Valve And Rocker Arm 100k0781010601 Inlet Manifold 100k0781010602 Exhaust Manifold 100k0781010700 Hydraulic Pump 100k0781010701 Hydraulic Pump[component Parts]100k0781010900 Upper Gasket Kit[option]100k0781010901 Lower Gasket Kit[option]100k0781010908 Piston Kit [option] 100k0781030603 Air Cleaner 100k0781030605 Muffler 100k078103a00101 Accelerator Lever 100k0781fuel System 03a101 Fuel Tank 100k078103a11001 Fuel Pipe 100k0781cooling Water System 03a41001 Water Pipe 100k078103a42001 Radiator 100k0781electrical System 03a53501 Battery 100k0781​
