Item Part No. Description Book Engine 011001 Crank Case 100k0658011002 Oil Pan 100k0658011003 Cylinder Head 100k0658011004 Gear Case 100k0658011005 Head Cover 100k0658011006 Oil Filter 100k0658011007 Dipstick And Guide 100k0658011008 Oil Pump 100k0658011100 Main Bearing Case 100k0658011101 Camshaft And Idle Gear Shaft 100k0658011102 Piston And Crankshaft 100k0658011103 Flywheel 100k0658011105 Fuel Camshaft 100k0658011200 Governor 100k0658011202 Caburettor 100k0658011204 Fork Lever 100k0658011205 Speed Control Lever 100k0658011300 Spark Plug And Distributor 100k0658011301 Distributor (Component Parts) 100k0658011402 Alternator And Pulley 100k0658011403 Alternator (Component Parts) 100k0658011404 Starter 100k0658011405 Starter (Component Parts) 100k0658011406 Oil Switch/thermometer And Plug 100k0658011500 Water Flange And Thermostat 100k0658011501 Water Pump 100k065801150101 Water Pump 100k0658011503 Water Pipe 100k0658011504 Fan 100k0658011600 Valve And Rocker Arm 100k0658011601 Inlet Manifold 100k0658011602 Exhaust Manifold 100k0658011905 Gasket Kit 100k0658021603 Air Cleaner 100k0658021605 Muffler 100k0658fuel System 02a010 Accelerator Lever 100k065802a015 Choke Wire 100k065802a100 Fuel Tank 100k065802a120 Fuel Pipe/fuel Filter 100k0658cooling Water System 02a210 Water Pipe 100k065802a220 Radiator 100k0658electrical System 02b010 Battery 100k065802b100 Electrical Parts 100k065802b200 Head Light 100k065802b500 Electrical Wiring 100k0658transmission/hst/rear Axle 02c100 Transmission Case 100k065802c120 Brake Gear-shaft/idler Shaft 100k065802c400 Hst 100k065802c405 Hst [component Parts] 100k065802c420 Universal Joint/hst Fan 100k065802c600 Pto Shaft 100k065802c620 Pto Tension Pulley 100k065802c800 Rear Differential 100k065802c810 Rear Differential Shaft 100k065802d010 Rear Axle Case 100k065802d100 Rear Axle 100k065802d200 Rear Wheel 100k0658brake/speed Change Pedal 02d500 Pto Brake 100k065802d510 Brake 100k0658
