Item Part No. Description Book Engine 01g027 Crankcase 100k017601g028 Oil Pan 100k017601g029 Piston/crankshaft 100k017601g030 Main Bearing Case 100k017601g031 Flywheel 100k017601g032 Cylinder Head 100k017601g033 Valve/rocker Arm 100k017601g034 Head Cover 100k017601g035 Inlet Manifold 100k017601g037 Exhaust Manifold 100k017601g039 Camshaft 100k017601g040 Gear Case 100k017601g041 Water Pump 100k017601g042 Water Flange/thermostat 100k017601g043 Distributor Shaft 100k017601g044 Carburettor 100k017601g045 Carburettor [component Parts] 100k017601g046 Fork Lever 100k017601g047 Governor 100k017601g048 Speed Control Lever 100k017601g049 Spark Plug 100k017601g050 Gasket Kit 100k017602g036 Air Cleaner 100k017602g038 Muffler 100k017602g051 Accelerator Lever 100k0176fuel System 02g052 Fuel Tank 100k017602g054 Fuel Pipe 100k0176cooling Water System 02g055 Radiator 100k017602g056 Fan 100k0176electrical System 02g057 Dynamo 100k017602g058 Dynamo [component Parts] 100k017602g061 Starter [component Parts] 100k017602g063 Battery 100k017602g064 Light 100k017602g065 Dashboard 100k017602g066 Dashboard 100k017602g067 Ignition Coil 100k017602g069 Wire Harness 100k0176transmission 02g070 Transmission Case 100k017602g071 Hst 100k017602g072 Hst [component Parts] 100k017602g073 Universal Joint/hst Fan 100k017602g074 Universal Joint/hst Fan 100k017602g075 Pto Shaft 100k017602g076 Tension Pulley 100k017602g077 Belt Retainer 100k017602g078 Rear Pto 100k017602g079 Rear Pto [component Parts] 100k0176speed Change 02g080 Cruise Control Plate 100k017602g081 Cruise Control Lever 100k017602g082 Speed Control Pedal 100k0176rear Axle 02g083 Rear Differential 100k017602g084 Rear Axle Case 100k017602g085 Rear Axle [2ws] 100k017602g086 Rear Wheel (23 X 10.5-12) [2ws] 100k0176brake 02g093 Pto Brake 100k017602g094 Brake Shaft 100k0176.
