Kubota G2000S Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01g027 Crankcase 100k017701g028 Oil Pan 100k017701g029 Piston/crankshaft 100k017701g030 Main Bearing Case 100k017701g031 Flywheel 100k017701g032 Cylinder Head 100k017701g033 Valve/rocker Arm 100k017701g034 Head Cover 100k017701g035 Inlet Manifold 100k017701g037 Exhaust Manifold 100k017701g039 Camshaft 100k017701g040 Gear Case 100k017701g041 Water Pump 100k017701g042 Water Flange/thermostat 100k017701g043 Distributor Shaft 100k017701g044 Carburettor 100k017701g045 Carburettor [component Parts] 100k017701g046 Fork Lever 100k017701g047 Governor 100k017701g048 Speed Control Lever 100k017701g049 Spark Plug 100k017701g050 Gasket Kit 100k017702g036 Air Cleaner 100k017702g038 Muffler 100k017702g051 Accelerator Lever 100k0177fuel System 02g052 Fuel Tank 100k017702g054 Fuel Pipe 100k0177cooling Water System 02g055 Radiator 100k017702g056 Fan 100k0177electrical System 02g057 Dynamo 100k017702g058 Dynamo [component Parts] 100k017702g061 Starter [component Parts] 100k017702g063 Battery 100k017702g064 Light 100k017702g065 Dashboard 100k017702g066 Dashboard 100k017702g067 Ignition Coil 100k017702g069 Wire Harness 100k0177transmission 02g070 Transmission Case 100k017702g071 Hst 100k017702g072 Hst [component Parts] 100k017702g073 Universal Joint/hst Fan 100k017702g074 Universal Joint/hst Fan 100k017702g075 Pto Shaft 100k017702g076 Tension Pulley 100k017702g077 Belt Retainer 100k017702g078 Rear Pto 100k017702g079 Rear Pto [component Parts] 100k0177speed Change 02g080 Cruise Control Plate 100k017702g081 Cruise Control Lever 100k017702g082 Speed Control Pedal 100k0177rear Axle 02g083 Rear Differential 100k017702g084 Rear Axle Case 100k017702g087 Rear Axle [4ws] 100k017702g088 Rear Axle Joint [4ws] 100k017702g089 Knuckle Arm [4ws] 100k017702g090 Tie Rod [4ws] 100k017702g091 Drag Link [4ws] 100k017702g092 Rear Wheel (23 X 8.50-12) [4ws] 100k0177brake 02g093 Pto Brake 100k0177​
