Item Part No. Description Bookengine 01g001 Crankcase 100k018201g002 Oil Pan 100k018201g003 Piston/crankshaft 100k018201g004 Main Bearing Case 100k018201g005 Flywheel 100k018201g006 Cylinder Head 100k018201g007 Valve/rocker Arm 100k018201g008 Nozzle Holder/glow Plug 100k018201g009 Nozzle Holder [component Parts] 100k018201g010 Head Cover 100k018201g011 Inlet Manifold 100k018201g013 Exhaust Manifold 100k018201g015 Camshaft 100k018201g016 Gear Case 100k018201g017 Water Pump 100k018201g018 Water Flange/thermostat 100k018201g019 Injection Pump 100k018201g020 Injection Pump [component Parts] 100k018201g021 Speed Control Plate 100k018201g022 Governor 100k018201g023 Stop Solenoid 100k018201g024 Upper Gasket Kit 100k018201g025 Lower Gasket Kit 100k018202g012 Air Cleaner 100k018202g014 Muffler 100k018202g026 Accelerator Lever 100k0182fuel System 02g052 Fuel Tank 100k018202g053 Fuel Pipe 100k0182cooling Water System 02g055 Radiator 100k018202g056 Fan 100k0182electrical System 02g057 Dynamo 100k018202g058 Dynamo [component Parts] 100k018202g059 Starter [component Parts] 100k018202g060 Starter [component Parts] 100k018202g062 Battery 100k018202g064 Light 100k018202g065 Dashboard 100k018202g066 Dashboard 100k018202g068 Wire Harness 100k0182transmission 02g070 Transmission Case 100k018202g071 Hst 100k018202g072 Hst [component Parts] 100k018202g073 Universal Joint/hst Fan 100k018202g074 Universal Joint/hst Fan 100k018202g075 Pto Shaft 100k018202g076 Tension Pulley 100k018202g077 Belt Retainer 100k018202g078 Rear Pto 100k018202g079 Rear Pto [component Parts] 100k0182speed Change 02g080 Cruise Control Plate 100k018202g081 Cruise Control Lever 100k018202g082 Speed Control Pedal 100k0182rear Axle 02g083 Rear Differential 100k018202g084 Rear Axle Case 100k018202g087 Rear Axle [4ws] 100k018202g088 Rear Axle Joint [4ws] 100k018202g089 Knuckle Arm [4ws] 100k0182
