Kubota R400 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01001 Crank Case 100k029601002 Oil Pan 100k029601004 Piston And Crank Shaft 100k029601005 Main Bearing Case 100k029601006 Cam Shaft 100k029601007 Cylinder Head 100k029601008 Valve And Rocker Arm 100k029601009 Cylinder Head Cover 100k029601010 Gear Case 100k0296air Intake System 01012 Inlet Manifold 100k0296fuel System 01015 Nozzle Holder And Glow Plug 100k029601016 Nozzle Holder (Section Parts) 100k029601017 Fuel Camshaft 100k029601018 Injection Pump 100k029601019 Injection Pump (Section Parts) 100k029601020 Engine Stop Lever 100k029601021 Speed Control Plate 100k029601022 Governor 100k0296cooling System 01026 Water Flange 100k029601027 Water Pump 100k0296electrical System 01029 Dynamo 100k029601030 Dynamo (Section Parts) 100k029601031 Flywheel And Starter 100k0296engine 01003 Sub Oil Pan 100k029601011 Engine Bracket 100k0296air Intake System 01013 Air Cleaner 100k0296exhaust System 01014 Muffler And Exhaust Manifold 100k0296fuel System 0102302 Accel And Stop Rod [ktc Ktcl] 100k029601024 Fuel Piping 100k029601025 Fuel Tank 100k0296cooling System 01028 Radiater & Water Pipe 100k0296electrical System 01032 Battery 100k029601033 Switch (1) And Panel 100k029601034 Switch (2) And Regulator 100k029601035 Light 100k029601036 Electrical Wiring 100k0296transmission 01037 Transmission Case (1) 100k029601038 Transmission Case (2) 100k029601039 Clutch [c1 C2] 100k029601040 Brake [b1 B2] 100k029601041 Clutch (C3) & Brake (B3) 100k029601042 Couplung 100k029601043 Planetary Carrier 100k029601044 Clutch Shaft (1) 100k029601045 Clutch Shaft (2) 100k029601046 Transfer (Drive Shaft) 100k029601047 Transfer (Hydraulic Pump) 100k029601048 Speed Change Lever 100k029601049 Speed Change Linkage System 100k0296axle 01050 Drive Shaft 100k029601051 Differential Case (Front) 100k029601052 Spiral Bevel Gear (Front) 100k029601053 Differential (Front) 100k029601054 Axle (Front) 100k029601055 Differential Case (Rear) 100k029601056 Spiral Bevel Gear (Rear) 100k029601057 Differential (Rear) 100k029601058 Axle (Rear) 100k0296tire 01059 Tire And Wheel 100k0296steering 01060 Steering Cylinder And Controller (New Type) 100k0296​
