Item Part No. Description Book Engine 01t001 Crankcase 100k009201t002 Oil Pan 100k009201t003 Cylinder Head 100k009201t004 Gear Case 100k009201t005 Main Bearing Case 100k009201t006 Cylinder Head Cover 100k009201t007 Inlet Manifold 100k009201t008 Valve/rocker Arm 100k009201t009 Camshaft 100k009201t010 Engine Stop Lever 100k009201t011 Gear Pump 100k009201t012 Crankshaft/piston 100k009201t013 Flywheel 100k009201t014 Nozzle Holder 100k009201t015 Speed Control Plate 100k009201t016 Governor 100k009201t017 Water Flange 100k009201t018 Fuel Camshaft 100k009201t019 Water Pump 100k009201t082 Gear Pump [section Parts] 100k009201t083 Nozzle Holder [section Parts] 100k009201t084 Injection Pump [section Parts] 100k009201t085 Starter [section Parts] 100k009201t086 Dynamo [a] [section Parts] 100k0092transmission 01t020 Transmission Case And Differential Case 100k009201t021 Mid P.t.o 100k009201t022 Cover 100k0092rear Axle/rear Wheel 01t023 Axle Case 100k0092clutch 01t024 Clutch 100k0092transmission 01t025 1st Shaft And 2nd Shaft 100k009201t026 3rd Shaft 100k009201t027 4th Shaft 100k009201t028 Front Drive Shaft And 6th Shaft 100k009201t029 7th Shaft And Pto Shaft 100k0092rear Axle/rear Wheel 01t030 Rear Differential 100k009201t031 Rear Axle,and Rear Wheel (8.3-24)[b8200hst-ep] [a]100k009201t03101 Rear Axle,and Rear Wheel (12.4-16) 100k009201t03102 Rear Wheel (13.6-16) [b8200hst-ept,b8200hst-dpt]100k0092speed Change Lever 01t032 Speed Change Fork 100k009201t033 Front Drive Fork 100k009201t034 Rotary Speed Change Fork 100k0092brake 01t035 Brake 100k0092hydraulic System 01t036 Hitch 100k009201t037 Hydrostatic Transmission 100k009201t038 Case Cover And Lift Arm 100k009201t039 Control Valve 100k009201t040 Hydraulic Piping 100k009201t041 Hydraulic Block 100k0092steering 01t042 Steering 100k0092speed Change Lever 01t043 Speed Change Lever 1 100k009201t044 Speed Change Lever 2 100k009201t045 Speed Change 1 100k009201t046 Speed Change 2 100k0092clutch 01t047 Clutch Pedal And Brake Pedal 100k0092rear Axle/rear Wheel 01t048 Diff.lock Pedal 100k0092
