Item Part No. Description Book Engine 01e002 Crankcase 100k010001e003 Oil Pan 100k010001e004 Cylinder Head 100k010001e006 Gear Case 100k010001e007 Main Bearing Case 100k010001e008 Cylinder Head Cover 100k010001e009 Manifold 100k010001e010 Valve/rocker Arm 100k010001e011 Camshaft 100k010001e012 Piston/crankshaft 100k010001e013 Flywheel 100k010001e014 Injection Pump 100k010001e015 Nozzle Holder 100k010001e016 Engine Stop Lever 100k010001e017 Speed Control Plate 100k010001e018 Governor 100k010001e019 Hydraulic Pump 100k010001e021 Dynamo 100k010001e022 Water Flange 100k010001e023 Water Pump 100k010001e024 Injection Pump [section Parts] 100k010001e025 Nozzle Holder [section Parts] 100k010001e027 Dynamo [section Parts] 100k010001e028 Hydraulic Pump [section Parts] 100k0100transmission 01t001 Transmission Case 100k010001t002 Pto Cover 100k010001t003 Cover 100k010001t004 Case Cover 100k0100rear Axle/rear Wheel 01t005 Rear Axle Case 100k0100clutch 01t006 Clutch Rod 100k010001t007 Clutch 100k0100transmission 01t008 2nd Shaft 100k010001t009 3rd Shaft 100k010001t010 4th Shaft,5th Shaft 100k010001t011 Spiral Bevel Shaft 100k010001t012 Pto Shaft 100k010001t013 Reverse Shaft 100k0100rear Axle/rear Wheel 01t014 Rear Differential 100k010001t015 Rear Axle 100k010001t016 Rear Wheel (9.5-16) 100k010001t018 Rear Wheel (8-16) 100k010001t019 Rear Wheel (29 X 12.00-15) 100k010001t020 Rear Wheel (31 X 13.5-15) 100k010001t021 Rear Wheel Hub 100k0100speed Change Lever 01t022 Speed Change Fork 100k010001t023 Main Speed Change 100k010001t024 Aux. Speed Change 100k010001t025 Rotary Speed Change Fork 100k0100brake 01t026 Brake 100k0100hydraulic System 01t028 Hydraulic Pipe 100k010001t029 Hydraulic Block 100k010001t031 Hydraulic 2 100k0100steering 01t032 Steering 100k0100speed Change Lever 01t033 Speed Change Lever 100k0100brake 01t034 Brake Rod 100k010001t035 Pedal 100k0100transmission 01t036 Release Rod 100k0100
