Item Part No. Description Book Engine 01t001 Crankcase 100k009401t002 Oil Pan 100k009401t003 Cylinder Head 100k009401t004 Gear Case 100k009401t005 Main Bearing Case 100k009401t006 Cylinder Head Cover 100k009401t007 Inlet Manifold 100k009401t008 Valve/rocker Arm 100k009401t009 Camshaft 100k009401t010 Engine Stop Lever 100k009401t011 Gear Pump 100k009401t012 Piston/crankshaft 100k009401t013 Flywheel 100k009401t014 Nozzle Holder 100k009401t015 Speed Control Plate 100k009401t016 Governor 100k009401t017 Water Flange 100k009401t018 Fuel Camshaft 100k009401t019 Water Pump 100k0094hydraulic System 01t098 Gear Pump [section Parts] 100k0094engine 01t099 Nozzle Holder [section Parts] 100k009401t100 Nozzle Holder [section Parts] 100k009401t101 Injection Pump [section Parts] 100k0094electrical System 01t102 Dynamo [section Parts] 100k009401t104 Starter [section Parts] 100k0094transmission 01t020 Transmission Case 100k009401t021 Cover 100k009401t022 Axle Case 100k0094clutch 01t023 Clutch 100k0094transmission 01t024 1 St Shaft And 2 Nd Shaft 100k009401t025 3 Rd Shaft 100k009401t026 4 Th Shaft And Reverse Shaft 100k009401t027 Front Drive Shaft And 6 Th Shaft 100k009401t028 7th Shaft And Pto Shaft 100k0094rear Axle/rear Wheel 01t029 Rear Differential 100k009401t030 Rear Axle And Rear Wheel (8.3-24) [a] 100k009401t031 Rear Axle And Rear Wheel (12.4-16) 100k009401t032 Rear Wheel (13.6-16) [a] (T) 100k0094speed Change Lever 01t034 Main Speed Change 100k009401t035 Speed Change Fork 100k009401t036 Front Drive Fork 100k009401t037 Rotary Speed Change Fork 100k0094brake 01t038 Brake 100k0094hydraulic System 01t039 Hitch 100k009401t040 Case Cover And Lift Arm 100k009401t041 Control Valve 100k009401t042 Control Valve 100k009401t044 Hydraulic Piping 100k009401t045 Hydraulic Piping 100k009401t046 Hydraulic Block 100k009401t047 Hydraulic Block 100k0094steering 01t048 Steering 100k009401t049 Steering 100k0094speed Change Lever 01t050 Speed Change Lever 1 100k009401t051 Speed Change Lever 2 100k0094clutch 01t052 Clutch Pedal And Brake Pedal 100k0094
