Item Part No. Description Book Engine 01001 Crankcase 100k035001002 Oil Pan 100k035001003 Cylinder Head 100k035001004 Gear Case 100k035001005 Main Bearing Case 100k035001006 Inlet And Exhaust Manifold 100k035001007 Valve And Rocker Arm 100k035001008 Head Cover 100k035001009 Camshaft 100k035001010 Piston And Crankshaft 100k03500101101 Flywheel (Single Clutch) 100k03500101102 Flywheel (Dual Clutch) 100k035001012 Starter Section Parts 100k035001013 Nozzle Holder 100k035001014 Nozzle Holder Section Parts 100k035001015 Fuel Camshaft 100k035001016 Injection Pump Section Parts 100k035001017 Governor 100k035001018 Speed Control Plate 100k035001019 Engine Stop Lever 100k035001020 Dynamo 100k035001021 Dynamo Section Parts 100k035001022 Radiator 100k035001023 Water Pipe 100k035001024 Water Pump 100k03500102501 Clutch (Single Clutch) 100k03500102502 Clutch (Dual Clutch) 100k035001026 Oil Hydraulic Pump 100k035001027 Oil Hydraulic Pump Section Parts 100k0350body 01028 Bumper 100k035001029 Battery Support 100k035001030 Safety Cover 100k035001031 Mid Case 100k035001032 Clutch Rod 100k035001033 Steering Wheel 100k035001034 Hand Accelerator 100k035001035 Hood 100k035001036 Main Shift Lever 100k035001037 Gear Drive System 100k035001038 Counter Shaft 100k035001039 Conduct Shaft 100k035001040 Reverse Shaft 100k035001041 Spiral Bevel Pinion 100k035001042 Power Take-off Shaft 100k035001043 Speed Change System 1 100k035001044 Speed Change System 2 100k035001045 Pto Shift Lever 100k035001046 Differential Lock Pedal 100k035001047 Rear Axle 100k035001048 Transmission Case 100k035001049 Brake Pedal 100k035001050 Step 100k035001051 Panel 1 100k035001052 Panel 2 100k035001053 Head Lamp 100k035001054 Wiring Diagram 100k0350
