Item Part No. Description Book Engine 01001 Crankcase 100k035201002 Oil Pan 100k035201003 Cylinder Head 100k035201004 Gear Case 100k035201005 Main Bearing Case 100k035201006 Inlet And Exhaust Manifold 100k035201007 Valve And Rocker Arm 100k035201008 Head Cover 100k035201009 Camshaft 100k035201010 Piston And Crankshaft 100k03520101101 Flywheel (Single Clutch) 100k03520101102 Flywheel (Dual Clutch) 100k035201012 Starter Section Parts 100k035201013 Nozzle Holder 100k035201014 Nozzle Holder Section Parts 100k035201015 Fuel Camshaft 100k035201016 Injection Pump Section Parts 100k035201017 Governor 100k035201018 Speed Control Plate 100k035201019 Engine Stop Lever 100k035201020 Dynamo 100k035201021 Dynamo Section Parts 100k035201022 Radiator 100k035201023 Water Pipe 100k035201024 Water Pump 100k03520102501 Clutch (Single Clutch) 100k03520102502 Clutch (Dual Clutch) 100k035201026 Oil Hydraulic Pump 100k035201027 Oil Hydraulic Pump Section Parts 100k0352body 01028 Bumper 100k035201029 Battery Support 100k035201030 Safety Cover 100k035201031 Mid Case 100k035201032 Clutch Rod 100k035201033 Steering Wheel 100k035201034 Hand Accelerator 100k035201035 Hood 100k035201036 Main Shift Lever 100k035201037 Gear Drive System 100k035201038 Counter Shaft 100k035201039 Conduct Shaft 100k035201040 Reverse Shaft 100k035201041 Spiral Bevel Pinion 100k035201042 Power Take-off Shaft 100k035201043 Speed Change System 1 100k035201044 Speed Change System 2 100k035201045 Pto Shift Lever 100k035201046 Differential Lock Pedal 100k035201047 Rear Axle 100k035201048 Transmission Case 100k035201049 Brake Pedal 100k035201050 Step 100k035201051 Panel 1 100k035201052 Panel 2 100k035201053 Head Lamp 100k035201054 Wiring Diagram 100k035201055 Fuel Tank 100k035201056 Fuel Filter 100k035201057 Oil Hydraulic System 1 100k035201058 Oil Hydraulic System 2 100k0352
