Item Part No. Description Book Engine 01e001 Crankcase 100k000901e002 Oil Pan 100k000901e003 Cylinder Head 100k000901e004 Gear Case 100k000901e005 Breather 100k000901e006 Inlet Manifold 100k000901e007 Valve And Rocker Arm 100k000901e008 Cylinder Head Cover 100k000901e009 Camshaft 100k000901e010 Piston And Crankshaft 100k000901e011 Flywheel 100k000901e012 Oil Pump 100k000901e013 Nozzle Holder And Fuel Pipe 100k000901e014 Injection Pump 100k000901e015 Starter And Dynamo 100k000901e016 Water Flange 100k000901e017 Water Pump 100k000901e018 Hydraulic Pump Base 100k0009section Parts 01e019 Starter [section Parts] 100k000901e020 Dynamo [section Parts] 100k000901e021 Fuel Pump [section Parts] 100k000901e022 Injection Pump [section Parts] 100k000901e023 Fuel Filter [section Parts] 100k000901e024 Sedimenter [section Parts] 100k000901e025 Nozzle Holder [section Parts] 100k0009engine Control 01t001 Fuel Tank Rh 100k000901t002 Fuel Tank Lh 100k000901t003 Fuel Piping 100k000901t004 Accel.control Rod 100k000901t005 Double Air Cleaner 100k000901t006 Muffler 100k000901t007 Radiator 100k000901t008 Water Pipe 100k0009cab And Hood 01t009 Washer Tank 100k0009clutch 01t010 Clutch Housing 1 100k000901t011 Clutch Housing 2 100k0009transmission 01t012 Transmission Case 100k000901t013 Transmission Case Cover 100k0009front Axle 01t014 Front Axle Bracket 100k0009clutch 01t015 Clutch 100k000901t016 Clutch Fork 100k0009transmission 01t017 Pto Clutch Lever 100k000901t018 Pto Propeller Shaft 100k000901t019 First Shaft 100k000901t020 Counter Shaft 100k000901t021 Hi-lo Shift Gear Shaft 100k000901t022 Back Idle Shaft 100k000901t023 Half Speed Shaft 100k000901t024 Bevel Gear 100k0009rear Pto 01t025 Pto Shaft 1 100k000901t026 Pto Shaft 2 100k000901t027 Pto Shaft Cover 100k0009transmission 01t028 Main Speed Change Cover 100k000901t029 Main Speed Change Lever 100k000901t030 Main Speed Change Shift Fork 100k000901t031 Hi-lo Shift Fork 100k000901t032 Hi-lo Shift Lever 100k0009
