Kubota M5950DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01e028 Crankcase 100k001401e029 Oil Pan 100k001401e030 Cylinder Head 100k001401e031 Gear Case 100k001401e032 Breather 100k001401e033 Double Air Cleaner 100k001401e034 Muffler 100k001401e035 Valve And Rocker Arm 100k001401e036 Cylinder Head Cover 100k001401e037 Camshaft 100k001401e038 Piston And Crankshaft 100k001401e039 Flywheel 100k001401e040 Oil Pump 100k001401e041 Nozzle Holder And Fuel Pipe 100k001401e042 Injection Pump 100k001401e043 Starter And Dynamo 100k001401e044 Radiator 100k001401e045 Water Pump 100k001401e046 Hydraulic Pump Base 100k0014section Parts 01e047 Starter [section Parts] 100k001401e048 Dynamo [section Parts] 100k001401e049 Fuel Pump [section Parts] 100k001401e050 Injection Pump [section Parts] 100k001401e051 Fuel Filter [section Parts] 100k001401e052 Sedimenter [section Parts] 100k001401e053 Nozzle Holder [section Parts] 100k001401e054 Double Air Cleaner [sectionparts]100k0014engine Control 01t001 Fuel Tank 100k001401t002 Fuel Piping 100k001401t003 Hand Accelerator 100k001401t00402 Accelerator Pedal 100k001401t005 Engine Stop Rod 100k001401t00602 Air Cleaner Bracket 100k0014clutch 01t007 Clutch Housing 100k0014transmission 01t008 Transmisson Case 100k0014front Axle 01t009 Front Axle Bracket 100k0014clutch 01t01001 Clutch [old Type] 100k001401t01002 Clutch [new Type] 100k001401t011 Clutch Pedal 100k0014transmission 01t012 Pto Clutch Lever 100k001401t013 Pto Propeller Shaft 100k001401t014 Counter Shaft 100k001401t015 Back Idle Shaft 100k001401t016 Half Gear Shaft 100k001401t017 Hi-lo Shift Gear Shaft 100k001401t018 Bevel Gear 100k0014rear Pto 01t019 Power Take-off Shaft 100k001401t020 Pto Shaft Cover 100k0014transmission 01t021 Main Speed Change Shift Lever 100k001401t022 Hi-lo Shift Lever 100k001401t023 Hi-lo And Half Shift Lever 100k001401t024 Harf Shift Lever 100k0014rear Pto 01t025 Ground Pto Shift Lever 100k001401t026 Pto Brake 100k0014rear Axle 01t027 Differential System 100k001401t028 Diff Lock Pedal 100k0014​
