Item Part No. Description Book Engine 01e001 Crankcase 100k001201e002 Oil Pan 100k001201e003 Cylinder Head 100k001201e004 Gear Case 100k001201e005 Bearing Case 100k001201e006 Double Air Cleaner 100k001201e007 Muffler 100k001201e008 Valve And Rocker Arm 100k001201e009 Cylinder Head Cover 100k001201e010 Camshaft 100k001201e011 Piston And Crankshaft 100k001201e012 Flywheel 100k001201e013 Nozzle Holder 100k001201e014 Fuel Pump 100k001201e015 Speed Control 100k001201e016 Stop Solenoid 100k001201e017 Governor 100k001201e018 Dynamo 100k001201e019 Radiator 100k001201e020 Injection Pump 100k001201e021 Water Pump 100k0012section Parts 01e022 Oil Filter [section Parts] 100k001201e023 Starter [section Parts] 100k001201e024 Nozzle Holder [section Parts] 100k001201e025 Dynamo [section Parts] 100k001201e026 Injection Pump [section Parts] 100k001201e027 Double Air Cleaner [section Parts] 100k0012engine Control 01t001 Fuel Tank 100k001201t002 Fuel Piping 100k001201t003 Hand Accelerator 100k001201t00401 Accelerator Pedal 100k001201t005 Engine Stop Rod 100k001201t00601 Air Cleaner Bracket 100k0012clutch 01t007 Clutch Housing 100k0012transmission 01t008 Transmisson Case 100k0012front Axle 01t009 Front Axle Bracket 100k0012clutch 01t01001 Clutch [old Type] 100k001201t01002 Clutch [new Type] 100k001201t011 Clutch Pedal 100k0012transmission 01t012 Pto Clutch Lever 100k001201t013 Pto Propeller Shaft 100k001201t014 Counter Shaft 100k001201t015 Back Idle Shaft 100k001201t016 Half Gear Shaft 100k001201t017 Hi-lo Shift Gear Shaft 100k001201t018 Bevel Gear 100k0012rear Pto 01t019 Power Take-off Shaft 100k001201t020 Pto Shaft Cover 100k0012transmission 01t021 Main Speed Change Shift Lever 100k001201t022 Hi-lo Shift Lever 100k001201t023 Hi-lo And Half Shift Lever 100k001201t024 Harf Shift Lever 100k0012rear Pto 01t025 Ground Pto Shift Lever 100k001201t026 Pto Brake 100k0012rear Axle 01t027 Differential System 100k001201t028 Diff Lock Pedal 100k001201t029 Rear Axle Case 100k001201t030 Rear Axle 100k0012steering 01t034 Steering Handle 100k0012
