Item Part No. Description Book Engine 01s001 Crankcase 100k067401s002 Oil Pan 100k067401s003 Oil Pipe (Turbo Charger) 100k067401s004 Piston/carnkshaft 100k067401s005 Main Bearing Case 100k067401s006 Camshaft 100k067401s007 Cylinder Head 100k067401s008 Valve/rocker Arm 100k067401s009 Cylinder Head Cover 100k067401s010 Gear Case 100k067401s011 Turbo Charger 100k067401s012 Inlet Manifold 100k067401s013 Exhaust Manifold 100k067401s014 Nozzle Holder/glow Plug 100k067401s015 Fuel Camshaft 100k067401s016 Injection Pump 100k067401s018 Engine Stop Lever 100k067401s019 Speed Control Plate 100k067401s020 Governor 100k067401s021 Water Pump 100k067401s022 Water Flange/thermostat 100k067401s023 Fan/alternator 100k067401s024 Alternator [component Parts] 100k067401s025 Flywheer/starter 100k067401s026-1 Starter [component Parts] [old Type] 100k067401s026-2 Starter [component Parts] [new Type] 100k0674engine Bracket 03s051 Engine Bracket 100k0674air Intake System 03s052-1 Air Cleaner [old Type] 100k067403s052-3 Air Cleaner [new Type] 100k067403s052-4 Air Cleaner [option] 100k0674exhaust System 03s053-1 Muffler 100k0674fuel System 03s054 Solenoid 100k067403s055 Fuel Tank 100k067403s056 Fuel Pipe 100k067403s057 Sedimenter 100k067403s058 Fuel Filter 100k0674cooling System 03s059 Radiator 100k067403s060 Water Pipe 100k0674electrical System 03s061 Battery 100k067403s062 Meter 100k067403s063 Switch 100k067403s064 Light 100k067403s065 Lamp 100k067403s066 Turn Signal 100k067403s067 Tail Lamp 100k067403s068 Electrical Wiring 100k0674transmission 03s069 Mission Case 100k0674axle 03s070 Front Axle Case 100k067403s071 Front Axle 100k067403s072 Front Differential Case 100k067403s073 Planetary Gear (Front) 100k067403s074 Front Differential 100k067403s075 Rear Axle Case 100k067403s076 Rear Axle 100k067403s077 Rear Differential Case 100k067403s078 Planetary Gear (Rear) 100k067403s079 Rear Differential 100k067403s080 Propeller Shaft 100k0674tire 03s081-1 Wheel/tire 100k0674
