Kubota L305DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k062701t002 Cylinder Head 100k062701t003 Gear Case 100k062701t004 Main Bearing Case 100k062701t005 Breather 100k062701t00601 Air Cleaner 100k062701t00602 Air Cleaner Double (Option) 100k062701t007 Muffler 100k062701t008 Valve Rocker Arm 100k062701t009 Head Cover 100k062701t010 Camshaft 100k062701t011 Piston Crankshaft 100k062701t012 Flywheel 100k062701t013 Nozzle Holder 100k062701t014 Fuel Camshaft 100k062701t015 Speed Control Plate 100k062701t016 Governor 100k062701t017 Dynamo 100k0627cooling Water System 01t018 Radiator 100k062701t019 Water Pump 100k0627section Parts 01t068 Oil Filter 2 100k062701t069 Starter 100k062701t070 Nozzle Holder 2 100k062701t071 Dynamo 100k062701t072 Injection Pump 100k0627front Axle/chassis 01t022 Front Axle Bracket 100k0627electrical System 01t023 Battery 100k0627transmission/clutch/rear Axle 01t024 Flywheel Housing 100k062701t025 Clutch Housing 100k062701t026 Clutch 100k062701t027 Clutch Pedal 100k0627steering 01t028 Steering 100k0627speed Change Lever/brake 01t029 Hand Accel 100k0627hood(Bonnet)/rops 01t030 Hood 100k062701t031 Head Lamp 100k062701t032 Seat 100k0627transmission/clutch/rear Axle 01t033 Trasnmission Case 100k062701t034 Transmission 1 100k062701t035 Transmission 2 100k062701t036 Transmission 3 100k062701t037 Speed Change System 1 100k062701t038 Speed Change System 2 100k062701t039 Speed Change System 3 100k062701t040 Differential System 1 100k062701t041 Differential System 2 100k062701t042 Rear Axle 100k062701t043 Axle Case 100k0627speed Change Lever/brake 01t044 Brake 100k062701t045 Brake Pedal 100k0627hood(Bonnet)/rops 01t046 Fender 100k0627electrical System 01t047 Electrical 1 100k062701t048 Electrical 2 100k062701t049 Electrical 3 100k0627fuel System 01t050 Fuel Tank 100k062701t051 Fuel Filter 100k0627hydraulic System 01t052 Oil Pressure 1 100k062701t053 Oil Pressure 2 100k062701t054 O/p Cylinder 100k062701t055 O/p Lift Arm System 100k062701t056 Top Link Bracket 100k0627​
