Item Part No. Description Book Engine 01001 Crankcase 100k012701002 Cylinder Head 100k012701003 Gear Case 100k012701004 Bearing Case 100k012701005 Breather 100k012701006 Air Cleaner 100k01270100701 Muffler [l185] 100k01270100702 Muffler [l185dt] 100k012701008 Valve,rocker Arm 100k012701009 Head Cover 100k012701010 Camshaft 100k012701011 Piston,crankshaft 100k012701012 Flywheel 100k012701013 Nozzle Holder 100k012701014 Fuel Camshaft 100k012701015 Speed Control Plate 100k012701016 Governor 100k012701017 Dynamo 100k012701018 Radiator 100k012701019 Name Plate 100k012701063 Starter 100k012701064 Nozzle Holder 100k012701065 Injection Pump 100k012701066 Dynamo 100k0127electrical System 01023 Battery 100k0127clutch 01024 Clutch Housing 100k012701025 Clutch 100k012701026 Clutch Pedal 100k0127steering 01027 Steering 100k0127speed Change Lever 01028 Hand Accel 100k0127bonnet And Cab And Rops 01029 Bonnet 100k0127electrical System 01030 Mirror,lamp 100k0127bonnet And Cab And Rops 01031 Seat 100k0127transmission 01032 Transmission Case 100k012701033 Gear Drive System 1 100k012701034 Gear Drive System 2 100k012701035 Gear Drive Syster 3 100k0127speed Change Lever 01036 Speed Change System 1 100k012701037 Speed Change System 2 100k012701038 Change Lever 100k0127front Axle And Front Wheel And Chassis 01039 Differential System 1 100k012701040 Differential System 2 100k0127rear Axle And Rear Wheel 01041 Rear Axle 100k012701042 Axle Case 100k0127brake 01043 Brake 100k012701044 Brake Pedal 100k0127bonnet And Cab And Rops 0104502 Fender [u.s.a] 100k0127electrical System 01046 Electical 1 100k012701047 Electical 2 100k012701048 Electical 3 100k0127fuel System 01049 Fuel Tank 100k012701050 Fuel Filter 100k0127hydraulic System 01051 Oil Pressure 1 100k012701052 Oil Pressure 2 100k012701053 O/p Cylinder 100k012701054 O/p Lift Arm System 100k0127front Axle And Front Wheel And Chassis 01055 Front Wheel [l185dt] 100k0127
