Item Part No. Description Bookengine 01001 Crankcase 100k013001002 Cylinder Head 100k013001003 Gear Case 100k013001004 Bearing Case 100k013001005 Breather 100k013001006 Air Cleaner 100k01300100701 Muffler [l245dt] 100k01300100702 Muffler [l245] 100k013001008 Valve,rocker Arm 100k013001009 Head Cover 100k013001010 Camshaft 100k013001011 Piston Crankshaft 100k013001012 Flywheel 100k013001013 Nozzle Holder 100k013001014 Fuel Camshaft 100k013001015 Speed Control Plate 100k013001016 Governor 100k013001017 Dynamo 100k013001018 Radiator 100k013001019 Water Pump 100k013001020 Name Plate 100k013001063 Oil Filter 2 [section Parts] 100k013001064 Starter 100k013001065 Nozzle Holder 100k013001066 Injection Pump 100k013001067 Dynamo 100k0130front Axle And Front Wheel 01021 Front Wheel [l245] 100k013001022 Front Wheel Drive 100k013001023 Front Axle 100k0130electrical System 01024 Battery 100k0130clutch 01025 Clutch Housing 100k013001026 Clutch 100k013001027 Clutch Pedal 100k0130steering 01028 Steering 100k0130speed Change Lever 01029 Hand Accel 100k0130bonnet(Hood) And Chassis And Canopy 01030 Bonnet 100k0130electrical System 01031 Mirror Lamp 100k0130bonnet(Hood) And Chassis And Canopy 01032 Seat 100k0130transmission 01033 Transmission Case 100k013001034 Gear Drive System 1 100k013001035 Gear Drive System 2 100k013001036 Gear Drive System 3 100k0130speed Change Lever 01037 Speed Change System 1 100k013001038 Speed Change System 2 100k013001039 Change Laver 100k0130rear Axle And Rear Wheel 01040 Differential System 1 100k013001041 Differential System 2 100k013001042 Rear Axle 100k013001043 Axle Case 100k0130brake 01044 Brake 100k013001045 Brake Pedal 100k0130bonnet(Hood) And Chassis And Canopy 0104602 Fender [u.s.a] 100k0130electrical System 01047 Electical 1 100k013001048 Electical 2 100k013001049 Electical 3 100k0130fuel System 01050 Fuel Tank 100k013001051 Fuel Filter 100k0130hydraulic System 01052 Oil Pressure 1 100k013001053 Oil Pressure 2 100k013001054 O/p Cylinder 100k0130
