Kubota L345DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 0101 Crankcase 100k03560102 Cylinder Head 100k03560103 Gear Case 100k03560104 Main Bearing Case 100k03560105 Breather 100k0356010601 Air Cleaner 100k0356010602 Air Cleaner Double 100k0356010701 Muffler 100k0356010702 Muffler (Option) 100k03560108 Valve Rocker Arm 100k03560109 Head Cover 100k03560110 Camshaft 100k03560111 Piston Crankshaft 100k03560112 Flywheel 100k03560113 Injection Pump 100k03560114 Fuel Camshaft 100k03560115 Speed Control Plate 100k03560116 Governor 100k03560117 Dynamo 100k03560118 Radiator 100k03560170 Oil Filter 2 [section Parts] 100k03560171 Starter [section Parts] 100k03560172 Nozzle Holder 2 [section Parts] 100k03560173 Dynamo [section Parts] 100k03560174 Injection Pump [section Parts] 100k0356front Axle And Front Wheel 012101 Front Axle 100k0356electrical System 0122 Battery 100k0356clutch 0123 Flywheel Housing 100k03560124 Clutch Housing 100k03560125 Clutch 100k03560126 Clutch Pedal 100k0356steering 012701 Steering 100k0356012702 Steering (Integral Type Powersteering)100k03560128 Hand Accel 100k0356bonnet(Hood) And Chassis 0129 Hood 100k03560130 Head Lamp 100k03560131 Seat 100k0356transmission 0132 Transmission Case 100k03560133 Transmission 1 100k03560134 Transmission 2 100k03560135 Transmission 3 100k0356speed Change Lever 0136 Speed Change System 1 100k03560137 Speed Change System 2 100k03560138 Speed Change System 3 100k0356rear Axle And Rear Wheel 0139 Differential System 1 100k03560140 Differential System 2 100k0356014101 Rear Axle (13.6-28) 100k0356014102 Rear Axle (12.4-28) 100k03560142 Axle Case 100k0356brake 0143 Brake 100k03560144 Brake Pedal 100k0356bonnet(Hood) And Chassis 0145 Fender 100k0356electrical System 0146 Electrical 1 100k03560147 Electrical 2 100k0356​
