Kubota M5030 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k042701t002 Oil Pan 100k042701t003 Piston And Crankshaft 100k042701t004 Main Bearing Case 100k042701t005 Flywheel 100k042701t006 Cylinder Head 100k042701t007 Valve And Rocker Arm 100k042701t008 Nozzle And Glow Plug 100k042701t009 Cylinder Head Cover 100k042701t010 Inlet Manifold 100k042702t01101 Air Cleaner (Double) 100k042702t01102 Pre-cleaner [option] 100k042702t012 Air Cleaner (Double) [component Parts] 100k042702t013 Muffler And Exhaust Manifold 100k042702t014 Under Muffler (Low-profile Kit) [option] 100k042701t015 Camshaft 100k042701t016 Gear Case 100k042701t017 Oil Filter [component Parts] 100k042701t01801 Water Pump [old Type] 100k042701t01802 Water Pump [new Type] 100k042701t019 Water Flange And Thermostat 100k042701t020 Fuel Camshaft 100k042701t021 Injection Pump 100k042701t022 Injection Pump [component Parts] 100k042701t023 Engine Stop Lever 100k042701t024 Speed Control Plate 100k042701t025 Compensator 100k042701t026 Governor 100k042701t027 Upper Gasket Kit 100k042701t028 Lower Gasket Kit 100k042702t02901 Engine Stop Rod 100k042702t02902 Engine Key Stop Kit [option] 100k042702t030 Hand Accelerator 100k042702t031 Accelerator Pedal 100k0427fuel System 02t032 Fuel Tank 100k042702t033 Fuel Tank Support 100k042702t034 Fuel Pipe 100k042702t035 Fuel Filter [component Parts] 100k0427cooling Water System 02t036 Radiator 100k042702t037 Water Pipe 100k0427electrical System 02t038 Starter 100k042702t03901 Starter [old Type] [component Parts] 100k042702t03902 Starter [old Type] [component Parts] 100k042702t03903 Starter [new Type] [component Parts] 100k042702t040 Dynamo 100k042702t041 Dynamo [component Parts] 100k042702t042 Battery 100k042702t043 Panel Board 100k042702t044 Panel Board [component Parts] 100k042702t04501 Switch [except Su] 100k042702t04502 Switch [su Type] 100k042702t046 Light 100k042702t047 Working Light [option] 100k042702t048 Trailer Harness [option] 100k042702t04901 Electrical Wiring [except Su] 100k042702t04902 Electrical Wiring [su Type] 100k0427clutch 02t05001 Clutch 100k042702t051 Clutch Fork 100k042702t052 Clutch Pedal 100k0427​
