Item Part No. Description Bookengine 021001 Crankcase 100k0704021002 Oil Pan 100k0704021003 Cylinder Head 100k0704021004 Gear Case 100k0704021005 Head Cover 100k0704021006 Oil Filter 100k0704021007 Dipstick And Guide 100k0704021100 Main Bearing Case 100k0704021101 Camshaft And Idle Gear Shaft 100k0704021102 Piston And Crankshaft 100k0704021103 Flywheel 100k0704021104 Clutch 100k0704021105 Fuel Camshaft And Governor Shaft 100k0704021200 Engine Stop Lever 100k0704021201 Stop Solenoid 100k0704021202 Injection Pump 100k0704021203 Injection Pump [component Parts] 100k0704021204 Governor 100k0704021205 Speed Control Plate 100k0704021206 Nozzle Holder And Glow Plug 100k0704021207 Nozzle Holder [component Parts] 100k0704021301 Fuel Pump(Mechanical) 100k0704021400 Dynamo And Pulley 100k0704021401 Dynamo [component Parts] 100k0704021500 Water Flange And Thermostat 100k0704021501 Water Pump 100k0704021600 Valve And Rocker Arm 100k0704021601 Inlet Manifold 100k0704021602 Exhaust Manifold 100k0704021700 Hydraulic Pump 100k0704021701 Hydraulic Pump [component Parts] 100k0704021900 Upper Gasket Kit 100k0704021901 Lower Gasket Kit 100k0704031603 Air Cleaner 100k0704031605 Muffler 100k0704031910 Alternator Kit 100k0704031911 Alternator [component Parts] 100k070403a00103 Accelerator Lever [hst Type] 100k0704fuel System 03a10102 Fuel Tank 100k070403a11002 Fuel Pipe 100k070403a11003 Fuel Pipe 100k070403a130 Fuel Filter [component Parts] 100k0704cooling Water System 03a40102 Fan 100k070403a41002 Water Pipe 100k070403a42003 Radiator [except[au]] 100k070403a42004 Radiator [au] 100k070403a43003 Reserve Tank 100k0704electrical System 03a51002 Stop Solenoid 100k070403a52502 Starter 100k070403a53002 Starter [component Parts] 100k070403a53503 Battery [except[au]] 100k070403a53504 Battery [au] 100k070403b10103 Switch [hst Type] 100k070403b11502 Panel Board 100k070403b12002 Panel Board [component Parts] 100k070403b301 Head Light 100k070403b302 Hazard Light [old Type] 100k070403b304 Tail Light 100k070403b50103 Electrical Wiring [hst Type] 100k0704clutch 03c11002 Clutch Rod 100k0704
