Item Part No. Description Book Engine 021001 Crankcase 100k0703021002 Oil Pan 100k0703021003 Cylinder Head 100k0703021004 Gear Case 100k0703021005 Head Cover 100k0703021006 Oil Filter 100k0703021007 Dipstick And Guide 100k0703021100 Main Bearing Case 100k0703021101 Camshaft And Idle Gear Shaft 100k0703021102 Piston And Crankshaft 100k0703021103 Flywheel 100k0703021104 Clutch 100k0703021105 Fuel Camshaft And Governor Shaft 100k0703021200 Engine Stop Lever 100k0703021201 Stop Solenoid 100k0703021202 Injection Pump 100k0703021203 Injection Pump [component Parts] 100k0703021204 Governor 100k0703021205 Speed Control Plate 100k0703021206 Nozzle Holder And Glow Plug 100k0703021207 Nozzle Holder [component Parts] 100k0703021301 Fuel Pump(Mechanical) 100k0703021400 Dynamo And Pulley 100k0703021401 Dynamo [component Parts] 100k0703021500 Water Flange And Thermostat 100k0703021501 Water Pump 100k0703021600 Valve And Rocker Arm 100k0703021601 Inlet Manifold 100k0703021602 Exhaust Manifold 100k0703021700 Hydraulic Pump 100k0703021701 Hydraulic Pump [component Parts] 100k0703021900 Upper Gasket Kit 100k0703021901 Lower Gasket Kit 100k0703031603 Air Cleaner 100k0703031605 Muffler 100k0703031910 Alternator Kit 100k0703031911 Alternator [component Parts] 100k070303a00102 Accelerator Lever [manual T/m Type] 100k0703fuel System 03a10102 Fuel Tank 100k070303a11002 Fuel Pipe 100k070303a11003 Fuel Pipe 100k070303a130 Fuel Filter [component Parts] 100k0703cooling Water System 03a40102 Fan 100k070303a41002 Water Pipe 100k070303a42003 Radiator [except[au]] 100k070303a42004 Radiator [au] 100k070303a43003 Reserve Tank 100k0703electrical System 03a51002 Stop Solenoid 100k070303a52502 Starter 100k070303a53002 Starter [component Parts] 100k070303a53503 Battery [except[au]] 100k070303a53504 Battery [au] 100k070303b10102 Switch [manual T/m Type] 100k070303b11502 Panel Board 100k070303b12002 Panel Board [component Parts] 100k070303b301 Head Light 100k070303b302 Hazard Light [old Type] 100k070303b30201 Hazard Light [new Type] 100k070303b304 Tail Light 100k0703
