Kubota M5030SU Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k042901t002 Oil Pan 100k042901t003 Piston And Crankshaft 100k042901t004 Main Bearing Case 100k042901t005 Flywheel 100k042901t006 Cylinder Head 100k042901t007 Valve And Rocker Arm 100k042901t008 Nozzle And Glow Plug 100k042901t009 Cylinder Head Cover 100k042901t010 Inlet Manifold 100k042901t015 Camshaft 100k042901t016 Gear Case 100k042901t017 Oil Filter [component Parts] 100k042901t01801 Water Pump [old Type] 100k042901t01802 Water Pump [new Type] 100k042901t019 Water Flange And Thermostat 100k042901t020 Fuel Camshaft 100k042901t021 Injection Pump 100k042901t022 Injection Pump [component Parts] 100k042901t023 Engine Stop Lever 100k042901t024 Speed Control Plate 100k042901t025 Compensator 100k042901t026 Governor 100k042901t027 Upper Gasket Kit 100k042901t028 Lower Gasket Kit 100k042902t01101 Air Cleaner (Double) 100k042902t01102 Pre-cleaner [option] 100k042902t012 Air Cleaner (Double) [component Parts] 100k042902t013 Muffler And Exhaust Manifold 100k042902t014 Under Muffler (Low-profile Kit)[option]100k042902t02901 Engine Stop Rod 100k042902t02902 Engine Key Stop Kit [option] 100k042902t030 Hand Accelerator 100k042902t031 Accelerator Pedal 100k0429fuel System 02t032 Fuel Tank 100k042902t033 Fuel Tank Support 100k042902t034 Fuel Pipe 100k042902t035 Fuel Filter [component Parts] 100k0429cooling Water System 02t036 Radiator 100k042902t037 Water Pipe 100k0429electrical System 02t038 Starter 100k042902t03901 Starter [old Type] [component Parts] 100k042902t03902 Starter [old Type] [component Parts] 100k042902t03903 Starter [new Type] [component Parts] 100k042902t040 Dynamo 100k042902t041 Dynamo [component Parts] 100k042902t042 Battery 100k042902t043 Panel Board 100k042902t044 Panel Board [component Parts] 100k042902t04501 Switch [except Su] 100k042902t04502 Switch [su Type] 100k042902t046 Light 100k042902t047 Working Light [option] 100k042902t048 Trailer Harness [option] 100k042902t04901 Electrical Wiring [except Su] 100k0429​
