Item Part No. Description Book Engine 010001 Crankcase 100k0469010002 Oil Pan 100k0469010003 Cylinder Head 100k0469010004 Gear Case 100k0469010005 Head Cover 100k0469010100 Main Bearing Case 100k0469010101 Camshaft And Idle Gear Shaft 100k0469010102 Piston And Crankshaft 100k046901010301 Flywheel [w/o Ind-pto] 100k046901010303 Flywheel [with Ind-pto] 100k0469010105 Fuel Camshaft And Governorshaft100k0469010200 Engine Stop Lever 100k0469010202 Injection Pump 100k0469010203 Injection Pump [component Parts] 100k0469010204 Governor 100k0469010205 Speed Control Plate 100k0469010206 Nozzle Holder And Glow Plug 100k0469010207 Nozzle Holder [component Parts] 100k0469010500 Water Flange And Thermostat 100k0469010501 Water Pump 100k0469010600 Valve And Rocker Arm 100k0469010601 Inlet Manifold 100k046901090102 Upper Gasket Kit 100k0469010902 Lower Gasket Kit 100k0469010603 Exhaust Manifold/muffler 100k0469010604 Air Cleaner 100k046901a002 Stop Solenoide/engine Stop Wire 100k046901a01001 Accelerator Lever [except Hsttype]100k046901a01002 Accelerator Lever [hst Type] 100k046901a025 Accelerator Linkage [except Hsttype]100k046901a03001 Accelerator Rod [except Hsttype]100k046901a03002 Accelerator Rod [hst Type] 100k0469fuel System 01a101 Fuel Tank 100k046901a110 Fuel Pipe And Fuel Filter 100k046901a130 Fuel Filter [component Parts] 100k0469cooling Water System 01a401 Fan 100k046901a410 Water Pipe 100k046901a420 Radiator 100k046901a430 Reserve Tank 100k0469electrical System 01a515 Alternator 100k046901a520 Alternator [component Parts] 100k046901a525 Starter 100k046901a530 Starter [component Parts] 100k046901a535 Battery 100k046901b10201 Switch 1 [except Hst Type] 100k046901b10202 Switch 1 [hst Type] 100k046901b10301 Switch 2 [except Hst Type] 100k046901b10302 Switch 2 [hst Type] 100k046901b115 Panel Board 100k046901b120 Panel Board [component Parts] 100k046901b301 Light [old Type] 100k046901b30101 Light [new Type] 100k0469
