Kubota L3010DT/GST/HST Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 010001 Crankcase 100k0467010002 Oil Pan 100k0467010003 Cylinder Head 100k0467010004 Gear Case 100k0467010005 Head Cover 100k0467010100 Main Bearing Case 100k0467010101 Camshaft And Idle Gear Shaft 100k0467010102 Piston And Crankshaft 100k046701010301 Flywheel [w/o Ind-pto] 100k046701010303 Flywheel [with Ind-pto] 100k0467010105 Fuel Camshaft And Governorshaft100k0467010200 Engine Stop Lever 100k0467010202 Injection Pump 100k0467010203 Injection Pump [component Parts] 100k0467010204 Governor 100k0467010205 Speed Control Plate 100k0467010206 Nozzle Holder And Glow Plug 100k0467010207 Nozzle Holder [component Parts] 100k0467010500 Water Flange And Thermostat 100k0467010501 Water Pump 100k0467010600 Valve And Rocker Arm 100k0467010601 Inlet Manifold 100k046701090101 Upper Gasket Kit 100k0467010902 Lower Gasket Kit 100k0467010603 Exhaust Manifold/muffler 100k0467010604 Air Cleaner 100k046701a002 Stop Solenoide/engine Stop Wire 100k046701a01001 Accelerator Lever [except Hsttype]100k046701a01002 Accelerator Lever [hst Type] 100k046701a025 Accelerator Linkage [except Hsttype]100k046701a03001 Accelerator Rod [except Hsttype]100k046701a03002 Accelerator Rod [hst Type] 100k0467fuel System 01a101 Fuel Tank 100k046701a110 Fuel Pipe And Fuel Filter 100k046701a130 Fuel Filter [component Parts] 100k0467cooling Water System 01a401 Fan 100k046701a410 Water Pipe 100k046701a420 Radiator 100k046701a430 Reserve Tank 100k0467electrical System 01a515 Alternator 100k046701a520 Alternator [component Parts] 100k046701a525 Starter 100k046701a530 Starter [component Parts] 100k046701a535 Battery 100k046701b10201 Switch 1 [except Hst Type] 100k046701b10202 Switch 1 [hst Type] 100k046701b10301 Switch 2 [except Hst Type] 100k046701b10302 Switch 2 [hst Type] 100k046701b115 Panel Board 100k046701b120 Panel Board [component Parts] 100k046701b301 Light [old Type] 100k046701b30101 Light [new Type] 100k0467​
