Item Part No. Description Book engine 01000101 Crankcase 100k0829010002 Oil Pan 100k082901000301 Cylinder Head 100k0829010004 Gear Case 100k0829010005 Head Cover 100k0829010100 Main Bearing Case 100k0829010101 Camshaft And Idle Gear Shaft 100k082901010201 Piston And Crankshaft 100k082901010301 Flywheel 100k0829010105 Fuel Camshaft 100k0829010200 Engine Stop Lever 100k0829010202 Injection Pump 100k0829010204 Governor 100k0829010205 Speed Control Plate 100k0829010206 Nozzle Holder And Glow Plug 100k0829010207 Nozzle Holder [componentparts]100k0829010500 Water Flange And Thermostat 100k0829010501 Water Pump 100k0829010600 Valve And Rocker Arm 100k0829010601 Inlet Manifold 100k0829010603 Exhaust Manifold/muffler 100k0829010604 Air Cleaner 100k082901090101 Upper Gasket Kit 100k0829010902 Lower Gasket Kit 100k082901a01001 Accelerator Lever [except Hsttype]100k082901a01002 Accelerator Lever [hst Type] 100k082901a025 Accelerator Linkage [except Hsttype]100k0829fuel System 01a101 Fuel Tank 100k082901a11001 Fuel Pipe And Fuel Filter [excepthst Type]100k082901a11002 Fuel Pipe And Fuel Filter [hsttype]100k082901a130 Fuel Filter [component Parts] 100k0829cooling Water System 01a401 Fan 100k082901a410 Water Pipe 100k082901a42001 Radiator [except Hst Type] 100k082901a42002 Radiator [hst Type] 100k082901a430 Reserve Tank [hst Type] 100k0829electrical System 01a515 Alternator 100k082901a520 Alternator [component Parts] 100k082901a525 Starter 100k082901a530 Starter [component Parts] 100k082901a53501 Battery [except Hst Type] 100k082901a53502 Battery [hst Type] 100k082901b102 Switch/relay 100k082901b10301 Switch /sensor [except Hst Type] 100k082901b10302 Switch/sensor [hst Type] 100k082901b115 Panel Board 100k082901b120 Panel Board [component Parts] 100k082901b30301 Head Light [old Type] 100k082901b30302 Head Light [new Type] 100k082901b311 Hazard Light 100k082901b312 Rear Lamp 100k082901b50101 Electrical Wiring [except Hsttype]100k082901b50102 Electrical Wiring [hst Type] 100k0829
