Item Part No. Description Book Engine 01000101 Crankcase 100k072101000201 Oil Pan 100k072101000301 Cylinder Head 100k072101000401 Gear Case [rops Type] 100k072101000501 Head Cover [old Type] 100k072101000502 Head Cover [new Type] 100k072101010001 Main Bearing Case [old Type] 100k072101010002 Main Bearing Case [new Type] 100k0721010101 Camshaft And Idle Gear Shaft 100k072101010201 Piston And Crankshaft 100k072101010302 Flywheel [except Hst Type] 100k072101010303 Flywheel [hst Type] 100k072101010501 Fuel Camshaft 100k0721010200 Engine Stop Lever 100k0721010202 Injection Pump 100k0721010204 Governor 100k0721010205 Speed Control Plate 100k0721010206 Nozzle Holder And Glow Plug 100k0721010207 Nozzle Holder [component Parts] 100k072101050001 Water Flange And Thermostat [ropstype]100k0721010501 Water Pump 100k0721010600 Valve And Rocker Arm 100k0721010601 Inlet Manifold 100k0721010603 Exhaust Manifold/muffler 100k072101060401 Air Cleaner [rops Type] 100k072101090101 Upper Gasket Kit 100k072101090201 Lower Gasket Kit 100k072101a01001 Accelerator Lever [rops Type] 100k072101a020 Accelerator Pedal [except Hst Type] 100k0721fuel System 01a101 Fuel Tank 100k072101a11001 Fuel Pipe And Fuel Filter [rops Type] 100k072101a120 Fuel Filter 100k072101a130 Fuel Filter [component Parts] 100k0721cooling Water System 01a401 Fan 100k072101a410 Water Pipe 100k072101a42001 Radiator [except Hst Type] [rops Type] 100k072101a42002 Radiator [hst Type] [rops Type] 100k072101a43001 Reserve Tank [rops Type] 100k0721electrical System 01a51501 Alternator 100k072101a52001 Alternator [component Parts] [ropstype]100k072101a52501 Starter 100k072101a53001 Starter [component Parts] 100k072101a535 Battery 100k072101b10201 Switch/relay [rops Type] 100k072101b10301 Switch/sensor [except Cab [ca] Type] 100k072101b10401 Switch [manual T/m Type] 100k072101b10402 Switch [gst Type] 100k072101b10403 Switch [hst Type] 100k072101b11501 Panel Board [rops Type] 100k072101b120 Panel Board [component Parts] 100k072101b303 Head Light 100k072101b311 Hazard Light [rops Type] 100k072101b31201 Rear Lamp [rops Type] 100k072101b50301 Electrical Wiring [manual T/m Type] 100k072101b50302 Electrical Wiring [gst Type] 100k072101b50303 Electrical Wiring [hst Type] [rops Type] 100k0721clutch/transmission/rear Axle 01c10101 Clutch 100k0721
