Item Part No. Description Book Engine 010001 Crankcase 100k0559010002 Oil Pan 100k0559010003 Cylinder Head 100k0559010004 Gear Case 100k0559010005 Head Cover 100k0559010100 Main Bearing Case 100k0559010101 Camshaft And Idle Gear Shaft 100k0559010102 Piston And Crankshaft 100k055901010302 Flywheel [hst Type] 100k0559010105 Fuel Camshaft 100k0559010200 Engine Stop Lever 100k0559010202 Injection Pump 100k0559010203 Injection Pump [component Parts] 100k0559010204 Governor 100k0559010205 Speed Control Plate 100k0559010206 Nozzle Holder And Glow Plug 100k0559010207 Nozzle Holder [component Parts] 100k055901050001 Water Flange And Thermostat [ropstype]100k0559010501 Water Pump 100k0559010600 Valve And Rocker Arm 100k055901060101 Inlet Manifold [rops Type] 100k0559010901 Upper Gasket Kit 100k0559010902 Lower Gasket Kit 100k0559010603 Exhaust Manifold/muffler 100k055901060401 Air Cleaner [rops Type] 100k055901a002 Stop Solenoid/engine Stop Wire 100k055901a01002 Accelerator Lever [hst Type] [rops Type] 100k055901a03002 Accelerator Rod [hst Type] 100k0559fuel System 01a10101 Fuel Tank [rops Type] 100k055901a110 Fuel Pipe And Fuel Filter 100k055901a130 Fuel Filter [component Parts] 100k0559cooling Water System 01a401 Fan 100k055901a41001 Water Pipe [rops Type] 100k055901a420 Radiator 100k055901a43001 Reserve Tank [rops Type] 100k0559electrical System 01a51501 Alternator [rops Type] 100k055901a52001 Alternator [component Parts] [ropstype]100k055901a525 Starter 100k055901a530 Starter [component Parts] 100k055901a53501 Battery [rops Type] 100k055901b10202 Switch 1 [hst Type] [rops Type] 100k055901b10302 Switch 2 [hst Type] [rops Type] 100k055901b115 Panel Board 100k055901b120 Panel Board [component Parts] 100k055901b30401 Light 1 [rops Type] [old Type] 100k055901b30402 Light 1 [rops Type] [new Type] 100k055901b50102 Electrical Wiring [hst Type] [rops Type] 100k0559clutch/transmission/rear Axle 01c101 Clutch 100k055901c201 Clutch Lever 100k055901c30102 Clutch Pedal [hst Type] [rops Type] 100k055901c40102 Clutch Housing [hst Type] 100k055901c41002 Mid Case [hst Type] 100k055901c415 Hst [component Parts] [hst Type] 100k055901c42002 Transmission Case [hst Type] 100k055901d10102 Main Shaft [hst Type] 100k055901d103 Input Shaft [hst Type] 100k055901d107 Output Shaft [hst Type] 100k055901d12503 Spiral Bevel Pinion [hst Type] 100k0559
