Kubota L4310DT/GST/HST Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 010001 Crankcase 100k0491010002 Oil Pan 100k0491010003 Cylinder Head 100k0491010004 Gear Case 100k0491010005 Head Cover 100k0491010100 Main Bearing Case 100k0491010101 Camshaft And Idle Gear Shaft 100k0491010102 Piston And Crankshaft 100k049101010301 Flywheel [w/o Ind-pto] 100k049101010303 Flywheel [with Ind-pto] 100k0491010105 Fuel Camshaft 100k0491010200 Engine Stop Lever 100k0491010202 Injection Pump 100k0491010203 Injection Pump [component Parts] 100k0491010204 Governor 100k0491010205 Speed Control Plate 100k0491010206 Nozzle Holder And Glow Plug 100k0491010207 Nozzle Holder [component Parts] 100k049101050001 Water Flange And Thermostat [ropstype]100k0491010501 Water Pump 100k0491010600 Valve And Rocker Arm 100k049101060101 Inlet Manifold [rops Type] 100k049101090102 Upper Gasket Kit 100k0491010902 Lower Gasket Kit 100k0491010603 Exhaust Manifold/muffler 100k049101060401 Air Cleaner [rops Type] [old Type] 100k049101060402 Air Cleaner [rops Type] [new Type] 100k049101a002 Stop Solenoide/engine Stop Wire 100k049101a01001 Accelerator Lever [except Hst Type][rops Type]100k049101a01002 Accelerator Lever [hst Type] [rops Type] 100k049101a025 Accelerator Linkage [except Hst Type] 100k049101a03001 Accelerator Rod [except Hst Type][rops Type]100k049101a03003 Accelerator Rod [hst Type] 100k0491fuel System 01a10101 Fuel Tank [rops Type] 100k049101a110 Fuel Pipe And Fuel Filter 100k049101a130 Fuel Filter [component Parts] 100k0491cooling Water System 01a401 Fan 100k049101a41001 Water Pipe [rops Type] 100k049101a420 Radiator 100k049101a43001 Reserve Tank [rops Type] 100k0491electrical System 01a51501 Alternator [rops Type] 100k049101a52001 Alternator [component Parts] [ropstype]100k049101a525 Starter 100k049101a530 Starter [component Parts] 100k049101a53501 Battery [rops Type] 100k049101b10201 Switch 1 [except Hst Type] [rops Type][old Type]100k049101b10202 Switch 1 [except Hst Type] [rops Type][new Type]100k049101b10203 Switch 1 [hst Type] [rops Type] [old Type] 100k049101b10204 Switch 1 [hst Type] [rops Type] [new Type] 100k049101b10301 Switch 2 [except Hst Type] [rops Type] 100k049101b10302 Switch 2 [hst Type] [rops Type] 100k049101b115 Panel Board 100k049101b120 Panel Board [component Parts] 100k049101b30401 Light 1 [rops Type] [old Type] 100k0491​
