Kubota L5450DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t00102 Crankcase 100k036801t00203 Oil Pan 100k036801t00302 Piston And Crankshaft 100k036801t00402 Main Bearing Case 100k036801t00502 Flywheel 100k036801t00602 Cylinder Head 100k036801t00702 Valve And Rocker Arm 100k036801t00802 Nozzle Holder And Glow Plug 100k036801t00902 Cylinder Head Cover 100k036801t01002 Inlet Manifold 100k036801t01602 Camshaft 100k036801t01702 Gear Case 100k036801t01802 Water Pump 100k036801t01902 Water Flange And Thermostat 100k036801t02002 Fuel Camshaft 100k036801t02102 Injection Pump 100k036801t02202 Injection Pump [component Parts] 100k036801t02302 Engine Stop Lever 100k036801t024 Speed Control Plate 100k036801t025 Governor 100k036802t01102 Air Cleaner (Double) 100k036802t01201 Air Cleaner (Double) [old Type][component Parts]100k036802t01202 Air Cleaner (Double) [component Parts] 100k036802t013 Pre-cleaner [au] [nz] [[a] [ca] Option] 100k036802t01402 Exhaust Manifold 100k036802t01501 Muffler [old Type] 100k036802t01502 Muffler [new Type] 100k036802t01503 Under Muffler Pipe [option] 100k036802t02602 Upper Gasket Kit 100k036802t02702 Lower Gasket Kit 100k036802t028 Engine Stop Rod 100k036802t029 Accelerator Lever 100k036802t030 Accelerator Pedal 100k0368fuel System 02t031 Fuel Tank 100k036802t032 Fuel Tank Support 100k036802t033 Fuel Pipe 100k036802t034 Fuel Filter 100k036802t035 Fuel Filter [component Parts] 100k0368cooling Water System 02t036 Fan 100k036802t037 Radiator 100k036802t03802 Radiator Support 100k0368electrical System 02t03901 Dynamo [a] [au] [nz] 100k036802t03902 Dynamo [ca] 100k036802t04001 Dynamo [component Parts] 100k036802t04002 Dynamo [component Parts] 100k036802t041 Starter 100k036802t04201 Starter [old Type] [component Parts] 100k036802t04202 Starter [old Type] [component Parts] 100k036802t04203 Starter [new Type] [component Parts] 100k036802t04302 Battery 100k036802t044 Switch And Regulator 100k036802t045 Panel Board 100k036802t046 Panel Board [component Parts] 100k036802t04701 Light [a] [ca] 100k036802t04702 Light [au] [nz] 100k036802t048 Working Light [nz] 100k0368​
