Item Part No. Description Book Engine 01t001 Crankcase 100k018501t002 Oil Pan 100k018501t003 Piston/crankshaft 100k018501t004 Main Bearing Case 100k018501t005 Flywheel 100k018501t006 Cylinder Head 100k018501t007 Valve/rocker Arm 100k018501t008 Nozzle Holder 100k018501t009 Nozzle Holder [component Parts] 100k018501t010 Cylinder Head Cover 100k018501t011 Inlet Manifold 100k018501t013 Exhaust Manifold 100k018501t015 Camshaft 100k018501t016 Gear Case 100k018501t017 Water Pump 100k018501t018 Tension Pulley [ca] 100k018501t019 Water Flange 100k018501t020 Fuel Pump 100k018501t021 Injection Pump 100k018501t022 Injection Pump [component Parts] 100k018501t023 Engine Stop Lever 100k018501t024 Speed Control Plate 100k018501t025 Governor 100k018501t026 Upper Gasket Kit 100k018501t027 Lower Gasket Kit 100k0185electrical System 01t03501 Dynamo [a] [au] [nz] 100k018501t03502 Alternator [ca] 100k018501t03601 Dynamo [a] [au] [nz] [component Parts] 100k018501t03602 Alternator [ca] [component Parts] 100k0185clutch 01t045 Clutch 100k0185hydraulic System 01t096 Hydraulic Gear Pump 100k018501t097 Hydraulic Gear Pump [component Parts] 100k0185engine 02t012 Air Cleaner 100k018502t01401 Muffler 100k018502t01402 Horizontal Muffler [option] 100k018502t028 Engine Stop Rod 100k018502t029 Accelerator Lever 100k0185fuel System 02t030 Fuel Tank 100k018502t031 Fuel Pipe 100k018502t032 Fuel Filter [component Parts] 100k0185cooling Water System 02t03302 Water Pipe 100k018502t03402 Radiator 100k0185electrical System 02t037 Starter 100k018502t038 Starter [component Parts] 100k018502t039 Battery 100k018502t040 Light 100k018502t041 Working Light [option] 100k018502t04201 Panel/switch [a] [au] [nz] 100k018502t04202 Panel/switch [ca] 100k018502t043 Panel Board [component Parts] 100k018502t04401 Wire Harness [a] [au] [nz] 100k018502t04402 Wire Harness [ca] 100k0185clutch 02t046 Clutch Rod 100k018502t047 Clutch Pedal 100k018502t048 Clutch Housing 100k0185transmission 02t049 Transmission Case 100k018502t050 Transmission Case Cover 100k0185
