Item Part No. Description Book Engine 01t001 Crankcase 100k019401t002 Oil Pan 100k019401t003 Piston/crankshaft 100k019401t004 Main Bearing Case 100k019401t005 Flywheel 100k019401t006 Cylinder Head 100k019401t007 Valve/rocker Arm 100k019401t008 Nozzle Holder 100k019401t009 Nozzle Holder [component Parts] 100k019401t010 Cylinder Head Cover 100k019401t011 Inlet Manifold 100k019401t013 Exhaust Manifold 100k019401t015 Camshaft 100k019401t016 Gear Case 100k019401t017 Water Pump 100k019401t018 Tension Pulley [ca] 100k019401t019 Water Flange 100k019401t020 Fuel Pump 100k019401t021 Injection Pump 100k019401t022 Injection Pump [component Parts] 100k019401t023 Engine Stop Lever 100k019401t024 Speed Control Plate 100k019401t025 Governor 100k019401t026 Upper Gasket Kit 100k019401t027 Lower Gasket Kit 100k0194electrical System 01t03501 Dynamo [a Au] 100k019401t03502 Alternator [ca] 100k019401t03601 Dynamo [a Au] [component Parts] 100k019401t03602 Alternator [ca] [component Parts] 100k0194clutch 01t045 Clutch 100k0194hydraulic System 01t094 Hydraulic Gear Pump 100k019401t095 Hydraulic Gear Pump [componentparts]100k0194engine 02t012 Air Cleaner 100k019402t01401 Muffler 100k019402t01402 Horizontal Muffler [option] 100k019402t028 Engine Stop Rod 100k019402t029 Accelerator Lever 100k0194fuel System 02t030 Fuel Tank 100k019402t031 Fuel Pipe 100k019402t032 Fuel Filter [component Parts] 100k0194cooling Water System 02t03301 Water Pipe 100k019402t03401 Radiator 100k0194electrical System 02t037 Starter 100k019402t038 Starter [component Parts] 100k019402t039 Battery 100k019402t040 Light 100k019402t041 Working Light [option] 100k019402t04201 Panel / Switch [a Au] 100k019402t043 Panel Board [component Parts] 100k019402t04401 Wire Harness [a Au] 100k0194clutch 02t046 Clutch Rod 100k019402t047 Clutch Pedal 100k019402t048 Clutch Housing 100k0194transmission 02t049 Transmission Case 100k019402t050 Transmission Case Cover 100k0194
