Kubota B2150E Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase 100k019901t002 Oil Pan 100k019901t003 Piston/crankshaft 100k019901t004 Main Bearing Case 100k019901t00501 Flywheel 100k019901t006 Cylinder Head 100k019901t007 Valve/rocker Arm 100k019901t008 Nozzle Holder 100k019901t009 Nozzle Holder [component Parts] 100k019901t010 Cylinder Head Cover 100k019901t011 Inlet Manifold 100k019902t012 Air Cleaner 100k019902t013 Air Cleaner [component Parts] 100k019901t014 Exhaust Manifold 100k019902t015 Muffler 100k019901t016 Camshaft 100k019901t017 Gear Case 100k019901t018 Water Pump 100k019901t019 Water Flange/thermostat 100k019901t020 Fuel Camshaft 100k019901t021 Injection Pump 100k019901t022 Injection Pump [component Parts] 100k019901t023 Engine Stop Lever 100k019901t024 Speed Control Plate 100k019901t025 Governor 100k019901t026 Upper Gasket Kit 100k019901t027 Lower Gasket Kit 100k019902t028 Engine Stop Rod 100k0199fuel System 02t029 Accelerator Lever 100k019902t030 Fuel Tank 100k019902t031 Fuel Pipe 1 100k019902t032 Fuel Filter 100k019902t033 Fuel Pipe 2 100k0199cooling Water System 02t034 Water Pipe 100k019902t035 Radiator 100k019901t036 Fan 100k0199electrical System 01t037 Tension Pulley [ca] 100k019901t03801 Dynamo [a][au][nz] 100k019901t03802 Alternator [ca] 100k019901t03901 Dynamo [a][au][nz] [component Parts] 100k019901t03902 Alternator [ca] [component Parts] 100k019902t040 Starter 100k019902t041 Starter [component Parts] 100k019902t042 Battery 100k019902t043 Light 100k019902t044 Working Light [option] 100k019902t045 Panel/switch 100k019902t046 Panel Board [component Parts] 100k019902t04701 Wire Harness [a][au][nz] 100k0199clutch 01t04801 Clutch 100k019902t04901 Clutch Rod 100k019902t050 Clutch Pedal 100k019902t05101 Clutch Housing 100k0199transmission 02t052 Transmission Case 100k019902t05301 Transmission Case Cover 100k019902t05601 Propeller Shaft 100k019902t05701 1st Shaft/2nd Shaft 100k019902t058 3rd Shaft 100k019902t059 4th Shaft 100k0199​
