Kubota B2150HSD Instructions for Parts Books - Instruction Manual
Item Part No. Description Bookengine 01t001 Crankcase 100k020001t002 Oil Pan 100k020001t003 Piston/crankshaft 100k020001t004 Main Bearing Case 100k020001t00502 Flywheel 100k020001t006 Cylinder Head 100k020001t007 Valve/rocker Arm 100k020001t008 Nozzle Holder 100k020001t009 Nozzle Holder [component Parts] 100k020001t010 Cylinder Head Cover 100k020001t011 Inlet Manifold 100k020001t014 Exhaust Manifold 100k020001t016 Camshaft 100k020001t017 Gear Case 100k020001t018 Water Pump 100k020001t019 Water Flange/thermostat 100k020001t020 Fuel Camshaft 100k020001t021 Injection Pump 100k020001t022 Injection Pump [component Parts] 100k020001t023 Engine Stop Lever 100k020001t024 Speed Control Plate 100k020001t025 Governor 100k020001t026 Upper Gasket Kit 100k020001t027 Lower Gasket Kit 100k0200cooling Water System 01t036 Fan 100k0200electrical System 01t037 Tension Pulley [ca] 100k020001t03801 Dynamo [a][au][nz] 100k020001t03802 Alternator [ca] 100k020001t03901 Dynamo [a][au][nz] [component Parts] 100k020001t03902 Alternator [ca] [component Parts] 100k0200clutch 01t04802 Clutch 100k0200hydraulic System 01t103 Hydraulic Gear Pump 100k020001t104 Hydraulic Gear Pump [component Parts] 100k0200engine 02t012 Air Cleaner 100k020002t013 Air Cleaner [component Parts] 100k020002t015 Muffler 100k020002t028 Engine Stop Rod 100k0200fuel System 02t029 Accelerator Lever 100k020002t030 Fuel Tank 100k020002t031 Fuel Pipe 1 100k020002t032 Fuel Filter 100k020002t033 Fuel Pipe 2 100k0200cooling Water System 02t034 Water Pipe 100k020002t035 Radiator 100k0200electrical System 02t040 Starter 100k020002t041 Starter [component Parts] 100k020002t042 Battery 100k020002t043 Light 100k020002t044 Working Light [option] 100k020002t045 Panel/switch 100k020002t046 Panel Board [component Parts] 100k020002t04701 Wire Harness [a][au][nz] 100k020002t04702 Wire Harness [ca] 100k0200clutch 02t04902 Clutch Rod 100k020002t050 Clutch Pedal 100k020002t05102 Clutch Housing 100k0200transmission 02t052 Transmission Case 100k020002t05302 Transmission Case Cover 100k020002t054 Hst 100k020002t055 Hst [component Parts] 100k0200​
