Item Part No. Description Book Engine 01t001 Crankcase 100k039701t002 Oil Pan 100k039701t003 Piston And Crankshaft 100k039701t004 Main Bearing Case 100k039701t00501 Flywheel [w/o Ind-pto] 100k039701t00502 Flywheel [with Ind-pto] 100k039701t006 Cylinder Head 100k039701t007 Valve And Rocker Arm 100k039701t008 Nozzle Holder/glow Plug 100k039701t009 Nozzle Holder [component Parts]100k039701t010 Cylinder Head Cover 100k039701t011 Inlet Manifold 100k039701t014 Camshaft 100k039701t015 Gear Case 100k039701t016 Water Pump 100k039701t017 Water Flange And Thermostat 100k039701t018 Fuel Camshaft 100k039701t019 Injection Pump 100k039701t020 Injection Pump [component Parts]100k039701t021 Engine Stop Lever 100k039701t022 Speed Control Plate 100k039701t023 Governor 100k039701t02402 Upper Gasket Kit 100k039701t025 Lower Gasket Kit 100k039702t01201 Air Cleaner 100k039702t01202 Double Air Cleaner [option] 100k039702t013 Exhaust Manifold And Muffler 100k039702t026 Stop Solenoid And Engine Stopwire100k039702t027 Accelerator Lever 100k039702t028 Accelerator Linkage 100k039702t029 Accelerator Rod 100k0397fuel System 02t030 Fuel Tank 100k039702t031 Fuel Pipe And Fuel Filter 100k039702t032 Fuel Filter [component Parts] 100k0397cooling Water System 02t033 Fan 100k039702t034 Water Pipe 100k039702t035 Radiator 100k039702t036 Reserve Tank 100k0397electrical System 02t037 Alternator 100k039702t038 Alternator [component Parts] 100k039702t039 Starter 100k039702t040 Starter [component Parts] 100k039702t041 Battery 100k039702t042 Switch 100k039702t043 Panel Board 100k039702t044 Panel Board [component Parts]100k039702t045 Light 100k039702t046 Electrical Wiring 100k0397clutch 02t047 Clutch 100k039702t048 Clutch Lever 100k039702t049 Clutch Pedal 100k039702t05001 Clutch Housing [manual T/m Type]100k039702t05101 Mid Case [manual T/m Type][with Ind-pto]100k0397transmission 02t052 Transmission Case 100k0397
