Item Part No. Description Book Engine 01t001 Crankcase 100k039301t002 Oil Pan 100k039301t003 Piston And Crankshaft 100k039301t004 Main Bearing Case 100k039301t00501 Flywheel [w/o Ind-pto] 100k039301t00502 Flywheel [with Ind-pto] 100k039301t006 Cylinder Head 100k039301t007 Valve And Rocker Arm 100k039301t008 Nozzle Holder/glowplug100k039301t009 Nozzle Holder[component Parts]100k039301t010 Cylinder Head Cover 100k039301t011 Inlet Manifold 100k039301t014 Camshaft 100k039301t015 Gear Case 100k039301t016 Water Pump 100k039301t017 Water Flange Andthermostat100k039301t018 Fuel Camshaft 100k039301t019 Injection Pump 100k039301t020 Injection Pump[component Parts]100k039301t021 Engine Stop Lever 100k039301t022 Speed Control Plate 100k039301t023 Governor 100k039301t02401 Upper Gasket Kit 100k039301t025 Lower Gasket Kit 100k039302t01201 Air Cleaner 100k039302t01202 Double Air Cleaner[option]100k039302t013 Exhaust Manifold Andmuffler100k039302t026 Stop Solenoid Andengine Stop Wire100k039302t027 Accelerator Lever 100k039302t028 Accelerator Linkage 100k039302t029 Accelerator Rod 100k0393fuel System 02t030 Fuel Tank 100k039302t031 Fuel Pipe And Fuel Filter 100k039302t032 Fuel Filter [componentparts]100k0393cooling Water System 02t033 Fan 100k039302t034 Water Pipe 100k039302t035 Radiator 100k039302t036 Reserve Tank 100k0393electrical System 02t037 Alternator 100k039302t038 Alternator [componentparts]100k039302t039 Starter 100k039302t040 Starter [componentparts]100k039302t041 Battery 100k039302t042 Switch 100k039302t043 Panel Board 100k039302t044 Panel Board[component Parts]1
