Item Part No. Description Book Engine 010001 Crankcase 100k0742010002 Oil Pan 100k0742010003 Cylinder Head 100k0742010004 Gear Case 100k0742010005 Head Cover 100k0742010100 Main Bearing Case 100k0742010101 Camshaft And Idle Gear Shaft 100k0742010102 Piston And Crankshaft 100k0742010103 Flywheel 100k0742010105 Fuel Camshaft 100k0742010106 Balancer 100k0742010200 Engine Stop Lever 100k0742010202 Injection Pump 100k0742010204 Governor 100k0742010205 Speed Control Plate 100k0742010206 Nozzle Holder And Glow Plug 100k0742010207 Nozzle Holder [component Parts] 100k0742010500 Water Flange And Thermostat 100k0742010501 Water Pump 100k0742010600 Valve And Rocker Arm 100k0742010601 Inlet Manifold 100k0742010906 Upper Gasket Kit 100k0742010907 Lower Gasket Kit 100k0742010602 Exhaust Manifold 100k0742010603 Air Cleaner 100k0742010604 Air Cleaner [component Parts] 100k0742010607 Muffler 100k074201a010 Hand Accelerator Lever 100k074201a060 Engine Stop Wire 100k0742fuel System 01a110 Fuel Tank 100k074201a140 Fuel Pipe 100k074201a180 Fuel Filter [component Parts] 100k0742cooling Water System 01a410 Fan 100k074201a420 Water Pipe 100k074201a430 Radiator 100k074201a450 Reserve Tank 100k0742electrical System 01a540 Alternator 100k074201a550 Alternator [component Parts] 100k074201a560 Starter 100k074201a570 Starter [component Parts] 100k074201a580 Battery 100k074201b015 Switch/sensor 100k074201b104 Switch(Panel Board)/relay 100k074201b140 Panel Board 100k074201b150 Panel Board [component Parts] 100k074201b320 Head Light 100k074201b335 Hazard Light/tail Light 100k074201b515 Electrical Wiring 100k0742clutch/transmission 01c110 Clutch Housing 100k074201c115 Bearing Holder 100k074201c140 Transmission Case 100k074201c150 Transmission Case Rear Cover 100k074201c170 Rear Axle Case 100k074201c210 Clutch 100k074201c230 Clutch Release Fork 100k074201c240 Clutch Pedal 100k074201d215 Input Shaft 100k074201d225 First Shaft 100k074201d227 Second Shaft 100k0742
